Old 03-21-2009, 08:54 PM   #1
Andy4639
Old member
Andy4639's Avatar
2 piece drive shaft
This is to show what you need for a 700-r4 install in a long bed with 2 piece drive shaft.
This picture shows both my shafts, I now have 2 for the truck. The one on the right is a 20 year old shaft that the same shop did for me.
You need a measurement from the end of the output shaft on the trans mission to the center of bearing mount. This was 33 1/2" for mine. Picture is for referance only.
The back half stays the same.
Overall length is 74" total.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-21-2009, 09:28 PM   #2
arkie726
arkie726's Avatar
Re: 2 piece drive shaft
Yep, I'm getting ready to put in a 700r as soon as the trany guy gets it done, then I have to get the shaft cut, but everyone says it will be worth the trouble!
arkie726 is offline   Reply With Quote
Old 03-22-2009, 04:41 AM   #3
Andy4639
Old member
Andy4639's Avatar
I wouldn't have it any other way for mine. Mine is driven daily and gets 18 MPG just back and forth to work. I have a stock 87 TPI 305 HO motor in it. I love it.
