![]() Join Date: Dec 2008
rear disc conversion
I have an 86 c10 with power disc brakes in the front and drum in the rear. I would like to convert the rears to disc. Do you need to change the master or just the proportioning valve when you do this? Thanks for any help.
Re: rear disc conversion
I forgot to add that I have a really lumpy cam in the motor. The lsa is about 110 degrees, so the brakes are a little sluggish due to the lack of vacuum as is.
profeshinaly unimployed
any one
"having mud flaps is like asking for a smaller trophy" |
Been reading some of the old threads. Can you use the front stock truck rotors with the 5x5 pattern on the back and use a mid 80's camaro caliper and buy or fab the mounting brackets?
If better brakes is what your looking for, the rear disc won't fix it. An ele. vac. pump would though.
'57 Chevy Pickup '56 GMC LCF Cummins '38 Chrysler Royal '57 2wd change http://67-72chevytrucks.com/vboard/s...light=speedway |
i have a vacuum pump i can install... but i was looking to do 4 wheel disc and solve the vacuum problem also... if that would work
Low & Fast!
You need to change both so you will have a Disc to Disc master and valve
