Old 03-22-2009, 07:50 AM   #1
jasonroman
jasonroman's Avatar
wondering what it takes to get 5/6 drop.
hey folks, question from a newbie. i know i will be told to search or not get reply. but id like to lower my new truck. 71 c10. v6. i looked at some kits but dont see 5/6 drops. mostley 3/4 with springs/blocks/spinle or shock. mainly id like to know if ill need to have the frame knotched? i was hoping not. only because i dont have lots to spend on the extra knotch. any help would be great. thanks,
and if you folks wouldnt mind posting a couple shots of trucks at different drop hights, that would be better than great.
jasonroman is offline   Reply With Quote
Old 03-22-2009, 08:31 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: wondering what it takes to get 5/6 drop.
No notch required with a 6" rear drop. Just install 6" drop springs
Use 2.5" drop spindles and a 2 or 3 inch drop spring. (4.5 or 5.5 inch front drop)
This will get the height correct,... but you still need to buy a few things.
1. Buy a good set of drop shocks.
2. Next you will need a set of shock relocators in the rear.
3. Buy an adjustable rear track bar. (panhard bar) this will allow you to re-center the rearend after you lower it.
Look at ECE (Early Classic Enterprises),... they should have everything you need.
Keith
Convert to disc brakes.
Old 03-22-2009, 08:59 AM   #3
see ten
WTB this ad
see ten's Avatar
You may want to be a little more conservative with your front drop. There are guys here that have done it and are happy with it, but that's a good bit of drop for the front. Tire clearances are going to be tight, and your control arms are going to be hanging very low. I'm not saying don't do it...just spend some more time lookinig around the site and ask some of the guys that have done it how happy they are with it as well as how do they use their trucks.
6" of drop out back shouldn't require a notch. I've got one that's lowered 6" in the back and I drive it hard and do haul stuff....and it does bottom out from time to time. My next one I do will be notched.
You're going to have a good bit of rake (or stink bug action) with that much drop in the front. Mine is dropped 6" out back and 3.5" in the front. If you do decide to go 5" in the front you might want to think about either using bags in the back or adding a block in with the 6" coils to get it down a bit more so the proportions will be right. Of course doing that would almost guarantee that you would have to notch the frame.
see ten is offline   Reply With Quote
Old 03-22-2009, 02:57 PM   #4
jasonroman
jasonroman's Avatar
thanks for reply fellas. i figured 5/6 cause i thought i read somewhere thats the way to go. i dont want to spend money on a drop kit and then be unhappy with drop. at the same time, i dont want a ride that rides like crap. dont have money for baggs.. maybe down the road a bit( quite a bit). im gonna check out ece now. also gonna look into cpp drop spindles...
Old 03-22-2009, 04:01 PM   #5
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here's the only link you will need.... Early Classic Enterpriseshttp://earlyclassic.com.
Other vendors offer the parts at a lower price, but you will not receive the amount of customer support/satisfaction like you will at ECE.
Keep us posted on what you decide to go with.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-22-2009, 04:30 PM   #6
jasonroman
jasonroman's Avatar
i was on there site a bit ago. looks like they have a 4/6 kit for 750. i thought the kit might be a little less. but seems to have most of the parts the guy who first responded told me id need. might end up going with them and that set up... we will see. thanks for help and replies guys.
any pics?
Old 03-22-2009, 04:36 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Check out this link.... it has ECE's drops on the same truck.
-Nate
Old 03-26-2009, 04:45 PM   #8
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
Question? Does anyone know where I can get a set of 6"drop springs for a 69'? I have looked in a lot of different spots and have yet to find any. Thanks for the help.
My Build Thread ..... http://67-72chevytrucks.com/vboard/s...d.php?t=288143
My Garage ..... http://www.hubgarage.com/mygarage/OCD69
jgrisafi is offline   Reply With Quote
Old 03-26-2009, 04:59 PM   #9
see ten
WTB this ad
see ten's Avatar
If you're asking for rear springs go to www.earlyclassic.com If you're wanting them for the front...they don't make em.
Old 03-26-2009, 05:19 PM   #10
72BlckButy
Tot Roddin'
72BlckButy's Avatar
x2 and refer to my post above for pictures of ECE 6" rear springs installed.
-Nate
Old 03-26-2009, 08:09 PM   #11
jgrisafi
Velocity Speed Shop
jgrisafi's Avatar
I guess I should have been ore specific, yes for the rear. Thanks for the good laugh though.
