Old 03-22-2009, 09:59 AM   #1
renegade6
Door adjustment and hinge pocket captured nut source
Does anyone know where I could find a captured nut and cage like the one inside of the red circle? I need it for an upper pillar pocket on a 57. The pocket is in good shape and I don't really want to buy one just for this.
Oh, and if anyone has any good suggestions on door adjustment, I'm all ears
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 03-22-2009, 10:17 AM   #2
blackdiesel
blackdiesel's Avatar
Re: Door adjustment and hinge pocket captured nut source
You would think someone would make a after market cage and nut, but in all the books I've look at I haven't seen them. Your best bet would be to get one off a junk cab. or do like I did and fab one up your self. It took me about 30min.. It might not have looked factory, but no one can see it anyway.
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-22-2009, 10:33 AM   #3
Kim57
Kim57's Avatar
These guys have caged nuts that may work.
Kim
http://www.mcmaster.com/#cage-nuts/=1438fa
Kim57 is offline   Reply With Quote
Old 03-22-2009, 07:35 PM   #4
renegade6
I found them @ Rico's.
Thanks for the other suggestions.
Brandon
Old 03-23-2009, 11:45 AM   #5
Houston54
Not sure if the nut is still secured or not but if it is you can also tap it out to the next largest size. I did not on the doors to my 54. I went with a coarse thread tap.
Houston54 is offline   Reply With Quote
Old 03-23-2009, 12:21 PM   #6
OrrieG
OrrieG's Avatar
Ace Hardware has them too in the bins. Slip on style and caged that you spot weld into place. Actually they have quite a bit of stuff, I cruise the aisle just looking at the different things trying to figure out cool applications to use them. MartinSR has a tech article on door, panel and hood adjusting, including the sequence. If you can't find it on this site camaros.com has all of his stuff. Look in the paint and body sections.
OrrieG is offline   Reply With Quote
Old 03-23-2009, 07:22 PM   #7
renegade6
Thanks for the tip on Ace. I've been buying most of my fasteners there lately, they have about the best selection anywhere.
Brandon
