![]() Join Date: Aug 2004
Sandwich-style carrier bearing re-do
Anyone who has the older style carrier bearing like this and thought you couldn't rebuild it...
![]() You can get a new bearing for it. The metal housing splits in half and a new bearing and rubber isolator are available. I had the driveshaft shop do it since I don't have a deep enough puller and the press fixtures at work wouldn't do it either. You CAN'T get a new housing if yours is screwed up, so that's why I didn't want to risk it and let the driveshaft folks handle it. They said they do about one of these a month.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
Old member
Re: Sandwich-style carrier bearing re-do
Well how does it look now?
I just did my 2 peice shaft this past week also.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Really, it doesn't look much different. New guts in an old housing. This is one of the few things I've repaired that I didn't slap some paint on before I put it back in. I just didn't have time...
Old member
I know that feeling. Got it out and get it back in to be ready for Monday Morning drive to work.
I could tell a big defferance in mine truck last night. That center bearing they said was shot. I couldn't even see out the rear veiw at speed. ![]() ![]()
Blowing the dust off this one!
I used a shop in Dallas to do my driveshaft work since I also needed it shortened for the 9" install. It was Driveshaft King, they didn't have any problem finding the part. Here's their # (214) 941-7122 The replacement part is the bearing and rubber, the 2 triangle pieces are re-used.
I had American Drivetrain in Ft.Worth shorten my driveshaft and balance it. To my surprise they painted it and made it look nice too. If anyone is in that area I'd recommend them. Does anyone know if there would be any more gains with a one piece driveshaft over a 2 piece?
-Bruton 1968 GMC long bed 5.7/700R4 --I'd rather push a Chevy, than drive a Ford.-- |
#7 | |
the boat guy
Op, wow one a month, these guys won't be in buisness long! Takes me about an hour, if I have to install ujoints and reballance it. Its pretty easy to remove a carrier bearing, cut it off, I usually use a cut off wheel on a die grinder. And as long as you're carefull you can put a new bearing with a punch on the inside race. We have drivers the correct size but that just makes us quicker. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
