03-22-2009, 12:39 PM | #1 |
Show me your 20s!
I'm looking to put 20" rims all around and need to see some pics of how they fit. Include the width, back spacing and tire size.
http://67-72chevytrucks.com/vboard/s...54#post3194654 |
03-22-2009, 01:32 PM | #2 |
SIR
Re: Show me your 20s!
IMHO...these trucks look awful as...."DONK"...and so do most of the others....
66long low fleet http://community.webshots.com/user/LVNR66 |
03-22-2009, 02:07 PM | #3 |
I didn't say, show me your 26s. Agreed about donks. I'm not lifting it up, I'm tucking them in.
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 03-22-2009 at 02:10 PM. |
03-22-2009, 02:10 PM | #4 |
Resistance is Futile
Here are my 20's: 20x8.5'' 5.5'' backspace. Little tite in the rear but workable.
SIR....... this is a DONK.......20's dont even qualify
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-22-2009, 02:13 PM | #5 |
SIR
...got it...point taken....
03-22-2009, 02:15 PM | #6 |
......ridiculous huh?
03-22-2009, 02:24 PM | #7 |
Godzilla, godzilla !!!!!!!!!!!!!!
1966 chevy c-20 truck " La Chata " under construccion |
03-22-2009, 04:04 PM | #8 |
that car is redonkulous. That burb looks great protrash. That's the stance I'm looking for. Do you have any pics from the side so I can see how they tuck? Is it bagged?
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 03-22-2009 at 04:05 PM. |
03-22-2009, 05:47 PM | #9 |
Yeah its bagged, but not notched. Tires are 275/45/20....so roughly 29-30'' tall. The fronts sit on the inner fender, the rear on the frame. It wasnt my goal to be on the ground, just bagged with basic stock components.
03-22-2009, 11:08 PM | #10 |
Where does the tire hit on the inner fenders? On the inside of the wheel first or turning? I don't have the wheels yet but may have to do the mods before I get them. How do you think I should clearance the inner fender so it doesn't rub? I have a notch in the back so I'll sit a little lower but I'd like my truck to look like this pic at ride height.
Beautiful CarryAll BTW.
http://67-72chevytrucks.com/vboard/s...54#post3194654 Last edited by shrunken66stroker; 03-22-2009 at 11:09 PM. |
03-23-2009, 12:02 AM | #11 |
The tire is resting against the inner fender directly above the hub, where the fender rolls over to horizontal and meets the inner fenderwell. If you want lower you must remove the inner fender and trim the fender edge...then you lose the hood hinge, also. You could build a tub, which is a popular option.
03-23-2009, 12:37 AM | #12 |
I've seen pics of tubs I think. That's probably the way I'll go. Thanks
03-23-2009, 03:53 PM | #13 |
Are you the only one on this site running 20s all around protrash?
03-23-2009, 07:58 PM | #14 |
I would find it difficult to believe if I am. I have 18's on my pickup. Dinos63 runs 20's and 20/22 combos. His trucks have custom suspension, however.
Post up some 20's people!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
03-23-2009, 08:14 PM | #15 |
I saw you mention rubbing here and on Dinos thread. I have no rubbing issues if you dont include the fender on the tire when its aired out. Turns are no problem ....can get a little rub when extreme turning due to my bump/steering stops removed.
Dont run tires larger than 45 series and you'll be fine. Discount tire direct has a tire size calculator you can use, FYI. Punch in #'s all you want.
03-23-2009, 11:39 PM | #16 |
here is mine 20x8.5 5.5BS Boyd Coddington Smoothie II's
tires are 275x20x40 front 275x20x45 rear
________________________ 62' 3.5/5 drop SWB Fleet, PS, PB-Dsk/Drm,350/700R4 08' Chevrolet Silverado CrewCab 05'Toyota Tacoma Prerunner SR5 |
03-24-2009, 11:52 AM | #17 |
Thanks 62step. I'm looking for more..... Anyone? 20s?
04-12-2009, 02:36 AM | #18 |
Last call for 20's all around... anyone?
04-12-2009, 11:37 AM | #19 |
Keep It Simple Stupid.. Nope..
Here's some pics of the front end with the wheel on but I haven't put longer studs in yet so I can't put them on and let it off the jack. But I will be running the 20's all around with matching Kumho 275/45/R20's. And the truck is at stock height though I'll probably do a 2" drop down the road.
1963 GMC SWB Fleetside in Sunburst Orange Metallic 305E V6 w/ Plaid VC, Powerglide, BOSS 313 20" Chrome Wheels, Kumho Ecsta STX 275/45/R20's, Alpine/Clarion System, Dynomax Exhaust Old custom classic trucks have soul. Their dashboards aren't plastic, and they've survived both the best and worst of what the 20th century had to offer. For the owners of these trucks, it's often the same story. Through both good and bad times they persevered, until one day they could turn the key and roll up in a customized truck everyone with good taste would admire. – Custom Classic Trucks Last edited by TwiggyTheDrummer; 04-12-2009 at 11:39 AM. |
04-12-2009, 03:29 PM | #20 |
I want to do 20's also but want the staggered look, deep in the back and shallow in the front.
04-12-2009, 05:17 PM | #21 |
Here a pic of my truck with Boss 303 Wheels. 8.5 in width and the tire is 275/45/R20.
87 2wd GMC Sierra Classic. 86 4wd GMC Sierra Classic. 95 2wd GMC Sierra. 96 2wd Chevrolet S-10. |
05-16-2009, 02:04 PM | #22 |
I'm reviving this thread because I'm about to special order some rims and I won't be able to return them once I get them. I'm ordering 20" rims that are 8 1/2" in the front and 10" wide in the back. I need to know if anyone has back space measurements so these rims will tuck in after the air is out of the bags. I'm thinking a zero offset on both front and back will work but I'm not sure. Anyone?
05-16-2009, 05:05 PM | #23 |
Heres mine dont know the backspace tho!
Tony from Norcal |
05-16-2009, 05:15 PM | #24 |
That's what I'm looking for. Could you possibly measure for me? From the back of the mounting flange to the inside edge of the rim. Are yours 8 1/2" wide all the way around?
05-16-2009, 09:01 PM | #25 |
man i really like the way your truck sits 64shortc10.
