Weekend Warrior
In the planning stages for a new project and need some opinions about gear selection.
I picked up a '72 K20 chassis with no axles. The plan is for a D60/14b FF axle combo. This will not be a trail rig or mud rig or anything like that, mainly for towing a car trailer etc. I might put a plow on it as well. A Work Truck. *I already have 2 Rear ends, one is a 14bFF 2wd with 3.73 gears & the Large brakes, the other is a 14bFF 4wd with 4.10 gears & the smaller brakes. *I already have a D60 front with 4.10 gears, but it is a "drive flange" front end from a Fulltime NP203 truck, so the hubs would have to be machined so I could put Lockouts in it. *I can get a D60 with 3.73 gears & lockouts for a reasonable price (IMO anyway) *I Plan to run a 235/85R16 tire - or something close. So that would be around 31.7" or we'll say 32" *Also plan on a TH400/NP205 combo behind a 350ci or 383ci. What do you guys think I should run for gears the 4.10's or the 3.73's. I'd like it to have good towing power but not be screaming @ 65-70mph either. Edit: Found a calculator, @ 65MPH with 4.10's and 31.7" tires I would be turning approx 2900rpm, with 3.73's it would be approx 2600rpm What's your honest opinion? Thanks! (oh and what would my D60 4.10 Front end be worth if I decided to go with the 3.73 one instead? $500 or so??)
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 03-22-2009 at 02:14 PM. |
Redefining LowBudget
Re: Gear Selection for a "street" 4x4??? - 4.10 or 3.73
what power if its a big block 3:73's if its a small block 3:73's since your in CT it's not like your going to pull any monster hills and you'll need the gear to run on 91
are they top pinion or bottom?? |
![]() Join Date: Feb 2007
i agree with hotrucks. i'd use the 3.73 with a big block or real torquey sb stroker, and definitely 4.10 with say a warm 350 and smaller. -steve
Steve 1971 GMC Longbox. Full Roller Stroker 489 w/ FiTech EFI, Chris Straub Cam/NV4500/205/D60/14B w. Grizzly Locker and 4.11's. 2" Lift on 33's |
#4 | |
Weekend Warrior
![]() The 4.10 D60 front is the standard low pinion axle. I thought maybe I could sell the D60/14bFF 4.10 Axle set together, and I also have a TH400/NP203 that someone who wanted to do an ORD doubler should be interested in. The TH400 was rebuilt recently and is in good shape.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 03-22-2009 at 04:24 PM. |
20' Daredevil (Ret)
![]() Join Date: May 2003
My K20 (350/350) has 4.10s. It's not bad at 55-60 mph, but if you will be doing any amount of 65-70 mph, I would honestly advise going with 3.73s. It'll be a bit less busy at higher speeds and may even help mpg just a little -- and you'll still have plenty of grunt for a work truck.
BTW, mine came stock with 7.50-16s and now has 33/12.50-16.5s, both ~32" tall.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay Last edited by Stocker; 03-24-2009 at 09:02 AM. |
I'd go 3.73's either way. Should be enough grunt.
Nice to see you posting again. Last edited by FormerMember; 04-02-2009 at 03:20 PM. |
Weekend Warrior
Thanks for the input guys.
Grendel - I'm really sorry about not calling you back. I'll PM you with some more information.
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
is the front a disc set up?? and what is the width and which side is the pinion ??? I need one for a ford and I want bottom loader with the pinion on the left.....for header clearance
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
I live in the catskill mountan reigion. my 71 has 3.73's and does verry well on the street I have towed with it, the PO towed insanely heavy loads with it. he showed me a recipt from the scrap yard scale that was around 12-13 thousand thats truck trailer and load. my truck has the sm465 granny low 4 speed with a 350 set up with a low rpm hi torque cam verry mild but runs well. I weighed out the option of the 350 vs 383 and for me it isnt worth the cash. theres a guy that does rebuilds at his machine shop and will do a 350 exchange short block for $650 the 383 was around $3000 all said and done.
I plan to install a nv4500 tranny in my truck and drive it daily. my tire size is 31's. good luck here are some usefull links for gear questions gm tranny ratios http://forum.snoman.com/viewtopic.php?t=153 handy calculators http://www.snoman.com/HTML/axlecalc_5a.html |
#10 | |
Weekend Warrior
Not that I recommend it, but I've had 12k rolling across the scales here, with my '94 1/2t Silverado 305/4L60E/3.42 geared truck ![]() ![]()
Do you have a 383 already?
Weekend Warrior
No, I was thinking about buying a Balanced Assembly and having 1 of my 15+ 350 blocks bored .030 or .040 over. Then getting a set of Vortec heads for it.
First things first, picking up the 3.73 D60 front (& hopefully selling the 4.10 D60/14bFF)
#13 |
I dont Know where you are in CT but a freind of mine had a 79 ford that he did some axle swaps on in torington at the raidiator shop on rt 4. just give Wayne a call he may swap you or know some one who would. pm me if you cant put that together.
#14 | |
I don't see a problem here. I put Husky Heavy Duty Selectro hubs on my full time D60 in my 1979 K30 right out of the box. I do prefer 3.73's on all my trucks that spend most of their time on highway. |
#15 |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Too bad you don't live close to me, I would buy those axles from ya. Good luck with the sell. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
#16 | |
Weekend Warrior
I've made the decision to go with the 3.73's thanks to all your recommendations. I have 2 options to get a D60 front with the 3.73's. 1 involves me buying it outright, and the other would be a partial trade (mine + cash). I think that I'm going to buy the one outright provided it is in good shape, and then sell my 4.10 D60/14bff as a set. Thanks again - Andy
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 03-23-2009 at 09:04 PM. |
#17 | |
A grinder will fix the axleshafts in about 2 mins. Last edited by FormerMember; 04-02-2009 at 03:20 PM. |
