Old 03-22-2009, 06:06 PM   #1
au03z71
au03z71's Avatar
Air Ride Big Red 4 way valve block question...
I posted this question in the Air-Ride Tech sale thread but thought I'd get more traffic here...
The big red 4-way valve block electrical receptacles for the solenoids are the plastic/harness plug-in type (i.e. male/female adapter), here's a link to a picture of what I'm talking about:
http://www.ridetech.com/products/Rid...1496-2501.html
From the picture, it is hard to tell which wires go to which valves and which are +/-.
Anyone with experience wiring one of these things up: Where can I find the female receplacle connectors that run to the switchbox/power supply, and how would I connect the wires to the receptacles? I couldn't find anything on their site...
Thanks!
au03z71 is offline   Reply With Quote
Old 03-22-2009, 10:25 PM   #2
joe231
joe231's Avatar
Re: Air Ride Big Red 4 way valve block question...
those 2 plugs are weather-pack connectors.....
you should be able buy the connectors and crimpers at your local auto parts store
looks like the wires to the ring terminals are ground and the 2 plugs with 4 wires each are the positive wires from each of the 8 solenoids.
how are you doing your switches?
are you running 4 SPDT switches?
CHEVY ONLY
Old 03-22-2009, 11:22 PM   #3
XXL
Seņor Member
XXL's Avatar
As joe231 says, those are the positive leads for each valve. By supplying constant ground (the ring terminals), all you do is throw momentary +12v onto any one wire to tell the valve what to do. Valve #1 has 2 wires... one "up" and one "down." Feed +12v onto one or the other. Ditto for the other valves.
If you're using momentary SPDT switches (often described as (ON)-OFF-(ON)), you'll feed +12v to the center of the switch, and then wire one valve's "up" and "down" to the outboard pins. Ditto for the other valves.
XXL is offline   Reply With Quote
Old 03-23-2009, 09:08 AM   #4
au03z71
au03z71's Avatar
OK good deal. You're right. The loop terminals are for ground and the 4 prong receptacles are for the + leads from the switch. I appreciate the help.
Old 03-23-2009, 09:40 AM   #5
joe231
joe231's Avatar
on a side note......
on that block, what size are the ports?
what is the advantage of a block over individual valves?
other than space savings?
CHEVY ONLY
Old 03-23-2009, 11:50 AM   #6
au03z71
au03z71's Avatar
None really, it just looks clean and compact. They have 3/8" ports and I'm going to use 1/4" line for the bags.
Another question, do the control panels that air-ride ride sells have the connectors that I was talking about?
Old 03-23-2009, 01:59 PM   #7
joe231
joe231's Avatar
CHEVY ONLY
