03-22-2009, 08:29 PM | #1 |
Anybody Cut the Front Bumpstop Brackets to Get a Little Lower?
I'm down in the front as far as I can go with cut coils, drop spindles, short shocks and everything else stock. I notice the front bumpstops sit on 2" or so high "bumps" on the lower A-arm. Has anybody cut out this "bump" that the bumpstop sits on to get a little more lower/supsension travel? It would seem I could gain another two inches of lowering/travel by cutting these "bumps" out and remounting some shorter (non factory) bumpstops.
If you've done this, some pics and descriptions would be most helpful. So what say you? As always, thanks for any and all help and/or suggestions. And thanks for this great forum.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" Last edited by terd ferguson; 03-22-2009 at 08:30 PM. |
03-22-2009, 08:33 PM | #2 |
Re: Anybody Cut the Front Bumpstop Brackets to Get a Little Lower?
Like I mentioned on the HAMB, my friend is thinking about doing that. We're trying to think of why they're there from the factory...? Maybe its cause with stock wheels/tires, they might hit the inner fender at full compression? Dunno, but it seems like cutting those brackets out would be helpful...
03-22-2009, 08:40 PM | #3 | |
I don't think fender clearance would be an issue with just a couple more inches. At least in my case, it looks like I'd be fine fender clearance wise. I found some bolt in bumpstops that are stepped so you can trim them to the desired length at the local Andvance Auto for pretty cheap. It seems like I could just cut that "bump", drill a hole, and bolt in the new bumpstops and gain two inches. But, I'd like to see if anybody else has done it first. :tito:
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" Last edited by terd ferguson; 03-22-2009 at 08:42 PM. |
03-22-2009, 08:42 PM | #4 |
Resistance is Futile
I cut them out on both my trucks....do it.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
03-22-2009, 08:44 PM | #5 |
Details? Got any pics? Did you reuse the factory bumpstops or something else? Any issues with tire/fender clearance, etc.? Thanks.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" Last edited by terd ferguson; 03-22-2009 at 08:44 PM. |
03-22-2009, 08:51 PM | #6 |
Well.....no pics. Just pop the a-arms down and drill the whole assembly off the LCA. I used a spotweld cutter. I did it for the same reason you mentioned and then I bought the appropriate sized tire so as not to have interference problems. I dont have any bumpstop in either of my trucks. The pick-up has 2.5'' spindles and 3'' coils and 26.5 '' diameter tires. I dont rub and have bottomed out only once when I hit a speedbump a little fast. Airbag guys remove it all the time.
03-22-2009, 08:54 PM | #7 | |
Thanks a lot for the info. I'm going to give it a shot in the next couple of days.
"I never apologize. I'm sorry, but that's just the way I am." - Homer J. Simpson 1955 2nd Series Chevy "King Of Trucks" |
03-22-2009, 08:58 PM | #8 |
If you're bottoming out it will free up the space. Just too bad you didnt do it when you had it apart before....but still worth the effort now. You could add a bumpstop on the edge of the coil pocket, I suppose???
03-22-2009, 09:40 PM | #9 | |
I don't think I'll have to take it back apart to get at it. I think I can just remove the tire, jack up the front end to let the control arms droop and cut the bump from there. The bumpstops I saw at the parts place had an integral bolt and would only need a small hole drilled in the LCA and thightening the nut.
03-23-2009, 12:07 AM | #10 |
I didnt think of that...probably work and if you have a righthand drill you should be able to get it done. Mite be able to grind them down, too.
07-12-2009, 01:02 PM | #11 |
SSN 706
Can you leave the a arms in place and cut the coils? I'll answer myself. No, take the time to clean the 50 years of crap off the u bolt nuts. Put a jack under the arms, jack it up alittle , undo the the u bolt nuts, remove and cut springs. Cut the springs with a grinder and cutting wheel. Replace in reverse order. Easy. Worse part was the cleaning.
Daverods 64 C10 Daily driver 292 3 speed "Driver" Daverods 66 Build C10 Bags 350/350(On Hold) Daverods 52 Build 3100 S10 chassis,Bags, 350/700r4 "Click it" Last edited by daverod; 07-18-2009 at 08:20 AM. |
07-12-2009, 08:07 PM | #12 |
good timing on this one... I am almost finished with my front end conversion. All the parts are from an 87 burb. It has 2.5" drop spindles and 3" coils. I know I will have to trim the bumpstops but do you think I will have issues with the bumpstop mount itself? I am running a 15" wheel. Here is a pic..
nothing hits now but obviously there is a lot of weight that is yet to be put back on the front. What do you guys think?
Jared USMC 1st Battalion 8th Marines (95-99) 55 1st Series 3100 (on 98 sonoma frame) 65 GMC short bed fleetside big back window http://67-72chevytrucks.com/vboard/s...d.php?t=358493 |
07-12-2009, 08:53 PM | #13 |
Hollister, CA.
Yeap...those are the first things to go if you want any 'travel' at all.
My truck uses stock spindles, cut springs and short shocks and it rides good.
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
07-12-2009, 10:50 PM | #14 | |
07-13-2009, 12:13 AM | #15 | |
yeah you are gonna want to remove those...from the pic you only seem to have a couple of inches of clearance, and like you said you have a lot more weight to go on the front
CHEVY ONLY |
07-13-2009, 12:47 AM | #16 |
I cut mine but left the steering stop portion in place. It may not look like it from this angle but it clears the upper plate to full bag compression:
07-13-2009, 12:59 AM | #17 |
I took mine totally off so its more aerodynamic and I can manuver drive thru's better, let alone the fuel savings
07-13-2009, 01:07 AM | #18 |
Mine also serve as vertical stabilizers and bottle openers when aired out
07-13-2009, 06:28 AM | #19 |
and a few others
I cut mine after I got it all together. Not by choice, just dumb. I used a sawzall. Not pretty, but it works.
Bill US Army Vet -193rd Infantry BlueRidgeMuscleCars.com “The greatness of a nation and its moral progress can be judged by the way its animals are treated” Gandhi |
07-13-2009, 06:44 AM | #20 |
thanks... fortunatley at this stage it will be easy to drop the lca's and remove them.... thanks fellas
07-17-2009, 12:28 PM | #21 |
Hey Chief how much did you cut off your springs, I really like the ride height of you truck.
1960 GMC short fleet, full frame build... http://67-72chevytrucks.com/vboard/s...d.php?t=329718 |
