Old 03-22-2009, 08:38 PM   #1
exmonkeypunk
Barrito Loco Diablo
exmonkeypunk's Avatar
whitened some tires this weekend
couple of things got done this weekend. I finally got the nuts to try painting on some white walls until i can afford nicer ones... i think they look great... Turns alot more heads. especially with the glass packs i put on last weekend.
[IMG][/IMG]
exmonkeypunk is offline   Reply With Quote
Old 03-22-2009, 08:39 PM   #2
*Dylan
Mean Buzzin' Half Dozen
*Dylan's Avatar
Re: whitened some tires this weekend
Lower that sucker now and it would look wicked!
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale)
1967 C10 SWB
Dylan
*Dylan is offline   Reply With Quote
Old 03-22-2009, 09:48 PM   #3
AlienYouth
AlienYouth's Avatar
x2
Picturesss
71 C10 383/TH400
13.65 @ 99... 2.06 60' spinnin :/
AlienYouth is offline   Reply With Quote
Old 03-23-2009, 08:09 AM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
x3... get that thing closer to the ground.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-23-2009, 10:10 AM   #5
xjmtdew
Just curious how did you paint the tires? I used the Krylon fusion paint and after 2 days it turned brown and flaked off.
xjmtdew is offline   Reply With Quote
Old 03-23-2009, 10:52 AM   #6
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Originally Posted by 72blckbuty View Post
x3... Get that thing closer to the ground. :d
x4!
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-23-2009, 10:58 AM   #7
69chevybmx
69chevybmx's Avatar
x5
low and slow.
69chevybmx is offline   Reply With Quote
Old 03-23-2009, 08:45 PM   #8
exmonkeypunk
Barrito Loco Diablo
I used.... surprisingly, Rustoleum vinyl paint. Cleaned them with bleach white first, let dry, then taped off and sprayed.... They're cracking some after a couple days, but still look great from over 5 feet.
I haven't decided if i'm lowering it or leaving it.... i'm on both sides of the fence.
Old 03-23-2009, 09:58 PM   #9
xjmtdew
You will have to let me know how that turns out. Maybe bleach white is the key to keeping it white?
Old 03-23-2009, 11:31 PM   #10
WOW! They look like real`40s wide whitewalls.
Old 03-23-2009, 11:58 PM   #11
tranz am
tranz am's Avatar
I have glass packs on mine too but I woulod rather have 40 series flows . I agree dump it down!
[IMG][/IMG]
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=456220
Best 1/4 mile time 12.1 @ 111 w/traction issues
1969 GMC SWB
1964 chevy II Nova ht
tranz am is offline   Reply With Quote
Old 03-24-2009, 05:20 AM   #12
OARNGESI
OARNGESI's Avatar
They look great
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-24-2009, 10:16 AM   #13
DtownSteve
Nice truck! I, too, am interested in seeing how they hold up to the elements. It's something I've always wanted to do but have been afraid to because I'm worried it would just flake off.
DtownSteve is offline   Reply With Quote
Old 03-24-2009, 12:49 PM   #14
El_Crnicero
El_Crnicero's Avatar
x6, i don't know how to post pics to the thread but here is a chop i did of it as an attachment.
El_Crnicero is offline   Reply With Quote
Old 03-24-2009, 02:11 PM   #15
rambler
MOVE OVER
rambler's Avatar
looks pretty good. I first thought you had ground down the tire to the white wall, as was discussed in a previous thread...
looks great lowered
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 03-24-2009, 09:46 PM   #16
exmonkeypunk
Barrito Loco Diablo
It's been raining nonstop for the last two days here. I haven't looked at the condition of the tires other than driving by when i get home from work. But from a few feet while rolling, they still look good. If you don't clean the tire enough before painting it, you are painting a dirty surface, plus, if you use paint that's for a solid surface, it won't adhere properly.
I didn't sand or scuff anything. Not even my knuckles. hah. I just sprayed it down with Bleach White, let it sit long enough for me to walk to the back of the house and fill a five gallon bucket with water from the hose, then i rinsed them off and went inside for an hour to let them dry off completely. Then i masked off at one of the lines before the tread pattern and used a knife to trim away the circle. I could've spent more time on the tape work. I would've had less touch up work needing to be done afterwards. The Rustoleum Vinyl paint, i thought would work being that it's for softer materials like Vinyl, plastic, leather, whatever. It seems to stick well to rubber. I did approx. 2 wetcoats, one over the other. I'm sure it would've been even nicer with more than 2 coats. But, I don't know where to find white walls that wide.... I think it looks great. I still wanna measure it and see how wide i have em'..... I found a set of air shocks for the rear that have a 7 inch drop. I figure i'll pick those up, then i'll need something for the front. This is all low buck, as you can see. How low can i go in the front without spending much money... It rides like a lumber wagon now anyways, so i'm not very concerned with that.
Old 03-24-2009, 10:10 PM   #17
exmonkeypunk
Barrito Loco Diablo
looks great lowered
I don't wanna try that one... haha. I do want to sand down the letters though and paint them with that rubber paint that's made for tires. I think it's like 50 bucks for enough to do 4 tires, so in reality, probably 100 bucks for 2 cans to do 4 really wide whites.
I'll keep you guys posted on how long it takes for these to look like crap. I noticed small cracking on 2 tires just now, but other than that, the rain cleaned them up more. haha. My boss and the other guys at work haven't seen the truck since i painted the wheels, but i told them about it and am getting alot of grief over it. I think comments and thumbs up on the truck have gone up by 3000 percent. Seriously. I don't drive anywhere without getting at least 2 people show approval in one way or another. Cheap alternative for a cool look in my book. so far it's good for 3 days. Here's the pics i got of the process.
The Cleaner
[IMG][/IMG]
Before.. The nervous truck awaits.
[IMG][/IMG]
The Paint
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old 04-01-2009, 08:41 PM   #18
exmonkeypunk
Barrito Loco Diablo
It's been almost a couple of weeks and the tires are still white. There's hairline cracks all over them, but i didn't do multiple coats just like 2 quit wetcoats. I think it wouldn't have cracked so quickly if i did 2 or 3 lighter coats. It gets alot of mixed opinions from everyone, but i like it, so that's what matters. I'm gonna start sanding the letters off the sidewalls within the next couple weeks and take more time masking and prepping the tires, then i'll use that rubber paint that's made for tires. It'll be alot more satisfying to allow people to view it up close. lol. I try not to get too concerned with what people think of my projects, but at the same time, you always want an opinion. The spray paint was a great decision to see how your vehicle would look with wide whites. Two thumbs up for this technique from me for the low buck look.
Old 04-01-2009, 09:26 PM   #19
VA72C10
VA72C10
VA72C10's Avatar
Thanks for keeping us up to date....please post when you sand the letters and paint with the new paint. Thanks! Rep added.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 04-11-2009, 09:11 PM   #20
exmonkeypunk
Barrito Loco Diablo
Ya know, this paint sticks pretty damn good for spray on. I'm surprised at how long it's lasting while not turning yellow or flaking off.
[IMG][/IMG]
Old 04-11-2009, 10:13 PM   #21
Mayo
Cool Truck
Mayo's Avatar
Looks good and I like the flames.
1968 Chevrolet C20 Longhorn "Cool Truck"
1937 Chevrolet Pickup - Project
Looking for a patina'd 68 50th Anniversary longbed
Mayo is offline   Reply With Quote
Old 04-11-2009, 10:18 PM   #22
exmonkeypunk
Barrito Loco Diablo
I get bored and the fine line tape comes out.I'll come up with something and drive around with it on for the weekend.
I was thinking add another set at the bottom of the quarter stretching to the middle of the door panel.
[IMG][/IMG]
[IMG][/IMG]
Old 04-12-2009, 12:51 AM   #23
reeve#30
reeve#30's Avatar
gotta love the shiftin knob, and i agree with you, its your truck do what you want with it, its unique and thats what you want, i love it
'67 chevy c-10 fleet, 350/350 turbo, edelbrock performer intake, holley 600 carb., k&n, headman headers, hurst rachet shifter
reeve#30 is offline   Reply With Quote
Old 04-14-2009, 08:22 PM   #24
exmonkeypunk
Barrito Loco Diablo
i finished the design i had in my head the other day.
[IMG][/IMG]
[IMG][/IMG]
Old 04-15-2009, 09:45 AM   #25
Mayo
Cool Truck
Mayo's Avatar
looks good
