Old 03-22-2009, 10:53 PM   #1
kylepatrick03
Dash Identification Help.
Ok, I have a dilemma, and thought I'd ask and see if someone out there has some insight. I picked up this 1965 and the PO replaced the cluster with a luan board (no joke) with miss-matched aftermarket gauges. In our restoration, we picked up a 65 cluster from a local vendor in texas, and it is way to small for the opening in the dash. Now I have compared the dash to pictures of the two different interior generations I'm aware of for this body style, the earlier years have a "hump" over the driver and passenger sides, and the later years have no humps, straight dash. This truck has a hump over the drivers side only....I'm at a loss. Pictures below, any help identifying what dash this is would be great, thanks,
Kyle
<br>
<br>
kylepatrick03 is offline   Reply With Quote
Old 03-22-2009, 11:37 PM   #2
19GMC63
19GMC63's Avatar
Re: Dash Identification Help.
Looks like you have a GMC cab, cause that is a GMC dash, the cluster is for a chevy.
19GMC63 is offline   Reply With Quote
Old 03-22-2009, 11:41 PM   #3
kylepatrick03
The VIN# on the cab matches the title which is chevy, so either the title is wrong, or they switched the dash. I am going tomorrow to get the vin#off the frame. The grill and hood are chevy, the tailgate was GMC, they did a redneck steel plate/smoothie job on it. I guess a lot can happen in 40+ years.
Did the chevy trucks in 65 have leaf spring rear ends? (this one does) I know in the 67-72's that was GMC specific.
Kyle
Old 03-22-2009, 11:58 PM   #4
protrash64
Resistance is Futile
protrash64's Avatar
x2 you also have a GMC frame!!!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 03-23-2009, 12:09 AM   #5
kylepatrick03
Yeah its a big mess at this point, I ran the title through a vin decoder online, not sure how accurate they are, came up a 61 chevy So far
Chevy Front clip
GMC Dash
GMC Frame
GMC Tailgate
Chevy Title, which decodes to an earlier year.
Oh boy, this is a fun one. thanks for your help.
Kyle
Old 03-23-2009, 12:11 AM   #6
19GMC63
19GMC63's Avatar
Kyle
The vin tag on the body has probably been changed.. doubt they switched the whole dash. Leafs were standard in GMCs I think, or at least very very common.
Old 03-23-2009, 12:12 AM   #7
protrash64
protrash64's Avatar
I just thought of something....you mite go thru the sticky up at the top about identifying different years of trucks....someone posted a bunch of GMC stuff there.
My truck is a total mutt....I have a GMC frame and Chevy cab.
Old 03-23-2009, 12:45 AM   #8
beefshreadder116
beefshreadder116's Avatar
atcually when i was at the junkyard a while ago, i found a chevy with a gmc dash. thought it was a hack job, but the truck looked original and was one solid faded color.
Projects:
66 gmc, SWB ,BBW,76 disc brakes/PS and rearend, pancaked crossmember 2 1/2" drop spindles 1 cut coil, 6" drop coils 2 " blocks c-notch with a 350.
beefshreadder116 is offline   Reply With Quote
Old 03-23-2009, 10:08 PM   #9
kylepatrick03
Well my frame VIN is different than my cab VIN, truck is titled to cab VIN, so not sure its a big deal, but the weird thing is the Title says CHEV under make. So in summary,
Grill/Hood - Chevy
Title - GMC (registered @dmv as a chevy)
GMC frame perhaps (has leafs, haven't decoded vin# yet to see year etc)
GMC Cab
Definitely a mutt, but its nice to know what breed of mutt I got.
Thanks All.
Kyle
