03-23-2009, 12:31 AM | #1 |
Will a 62 C-10 drop right on a 69 Frame?
I have a donor 69, that we want to use as a base....redue all bushings, springs, etc....and then drop a 62 front end/cab/bed (minimal down time this way)
Is this possible, well shoot I know most of you are going to say ANYTHINGS possible but is it a easy swap or alot of fabing? Thanks |
03-23-2009, 12:38 AM | #2 |
60-66 Nut
Re: Will a 62 C-10 drop right on a 69 Frame?
I'm thinking you'll have to fab or modify most if not all of the body mounts. For sure the front cab mounts and all of the bed mounts.
03-23-2009, 07:17 AM | #3 |
60-62 trucks will require more fabbing, especailly since the track width is so different. Close inspection of a 64 and a 72 pickup wil show you that they are pretty similar. 60-62 on a 69 frame, lots of fab. 63-66 on a 69 frame, alot less fab.
1982 K10 SWB 1987 V20 - Sold - Doh! |
