the bed down when the gas tank is at the back between the frame?
All I can think of is to weld the nuts on the frame. As I can't get my hand in there once the tank is in.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD |
Under Construction
Re: How are you guys bolting....
weld the nuts to the frame, or drop the tank, install the bed, then reinstall the tank. I wouldnt think you would be removing the bed much?
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
welding nuts for carrige bolts i somwhat nuts
you wouldn't think so....lately it is on and off on and off.
Ill have to check and see if I can get at the tank bolts. humm what about the Carage bolts with welded nuts won't work. I think I'll have to put the tank in last. Had tank and tire in the bed. now I have bags to put in and the tank is going under the bed now. (dirt bike needs the bed) CAA is my spare tire. Have to change the exhaust out the back, to infront of the rearend. All these changes.... Spring fever
hold carrige bolt in hand LOOK at it and figure whats wrong with this picture
I think I'll have to put the tank in last. Thanks guys. Have to make the tank go in and out nice nice
Under Construction
doh, i wasnt thinking straight but atleast i followed up with dropping the tank, install the bed , then install tank...
#8 | |
The Older Generation
![]() LockDoc
I used a self tapping sheetmetal screw. It has a 9/16 wrenching head probally 3/8 diameter shank. It has a rubber washer under the head. Hardest part was drilling a pilot hole in the hard frame.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" Last edited by Sammy; 03-23-2009 at 03:57 PM. Reason: edit |
#10 | |
So you are talking about the gas tank not the bed right>? ![]()
Tank is going back under the bed.
1968 Chevy C10 307 3ott fleetside 1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold 1967 Chev C/10 step, 383, M21. SOLD Last edited by 67chevemall; 07-09-2010 at 02:26 PM. |
