im Going to be Taking off the front clip from my uncles '85 C10 and was wondering if somebody had a picture with what bolts i need to remove. Thanks ahead of time
Low & Fast!
Re: Some Questions on taking off the front clip
This will get you started,
You can take it all off at one time fenders, inners and grill. You have your two body mounts up front behind the bumper, and then with the hood off two bolts on top of the fenders next to the windshild. Then open your doors and you will see one more at the top of the fender, then with the door closed look up under the front fender next to the door and you will see one more bolt. Make sure everything is unpluged and it sould come right off as one big part. That's all I can think of for right now. just look good for anything but it's very easy to do. Trav
Ok Thanks
Tags |
front clip removal |
