Old 03-23-2009, 04:15 PM   #1
Hawker7
Polyurethane or rubber motor mounts?
Does anyone use the Polyurethane? The seem pricey compared to the $16 I can set of stock onces at NAPA for. Was wondering if they are worth it?
Hawker7 is offline   Reply With Quote
Old 03-23-2009, 05:07 PM   #2
SactoJim
SactoJim's Avatar
Re: Polyurethane or rubber motor mounts?
My NAPA mount (drivers side) is history after only 3,000 miles and though I thought about spending the extra $$ on the poly type, I didn't.....wish I would of. I have quite a bit more hp than stock, So I should've known better.
Who has the best Price on these? Best I've seen is $90 for the pair.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-23-2009, 05:13 PM   #3
big_al_71
big_al_71's Avatar
Oh Boy I also have a little bit more power than stock. I wonder how long mine are going to last. It is one of those things that I did not think further ahead. Someone post a link to what you fellowes are looking at.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-23-2009, 05:25 PM   #4
Hawker7
Here is a set from Summit
http://store.summitracing.com/partde...5&autoview=sku
My motor is going to be around 290 HP. With that HP should I even bother with the poly's? How long do the rubber ones last? I really don't want to change them again.
Old 03-23-2009, 05:53 PM   #5
crapy67
White wall terror
crapy67's Avatar
Buy them, I don't have them in my truck (yet) but I do have them in my Nova, Well worth the money. Mine are from Energy Suspension.
crapy67 is offline   Reply With Quote
Old 03-23-2009, 06:15 PM   #6
my67chevytruck
Under Construction
my67chevytruck's Avatar
I have always heard that the poly squeak, and that they will bounce you around like crazy because they are soo stiff. is this true?
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-23-2009, 06:33 PM   #7
Eturnit3
Bloodied Knuckles
Eturnit3's Avatar
not sure how true it is but I heard the same thing about poly.
Eturnit3 is offline   Reply With Quote
Old 03-23-2009, 06:43 PM   #8
Hawker7
I think that was for the cab supports. Anyone else run the poly for motor mounts?
Old 03-23-2009, 06:45 PM   #9
sjarrett71
sjarrett71's Avatar
I wouldn't think they would bounce you around being motor mounts. I would say they might stiffen things up a bit so you don't get as much side to side flex.
sjarrett71 is offline   Reply With Quote
Old 03-23-2009, 07:04 PM   #10
Green Machine
Green Machine's Avatar
We bought the poly mounts when we put a 383 in the 1971. Didn't want anything breaking, BUT ........These mounts either stock of poly use a single 7/16 bolt to hold it to the frame. Dont remember on the stock mounts, but the poly mounts from Summit have threads in the 1/8 steel plate that is part of the mount. I'll bet there are only 3 or 4 threads in there to hold that bolt. The poly mounts will never break, but I'm not happy at all with the design of the "better" poly mounts. I am waiting for those threads to pull out and wreck something, won't buy any more unless they redo the design.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 03-23-2009, 08:53 PM   #11
big_al_71
big_al_71's Avatar
my truck has around 700 miles since completion and I just ran the motor for about ten minutes and it is solid no moving at all so I guess I will wait till I see them begin to tear.
Old 03-23-2009, 09:38 PM   #12
john02fxdl
I bought mine from Summit. A complete kit(motor mounts and trans mount). The poly motor and trans mounts are more durable and more resistant to oil, fuel and grease. They won't break down from chemicals and provide a stiffer mount as opposed to rubber. Will probably outlast your truck. The motor and trans mounts won't squeak because once everything is bolted down, they don't have a chance to move. Poly Cab mounts on the other hand also provide the same great benefits but also take away from the ride quality a bit. A little squeak here and there but not constant. Hope this helps.
Forgot to mention, you have to use a poly trans mount if you are going to use poly motor mounts, if not, too much flex in the tailshaft of trans and ...el cracko to the case.
When I grow up, I want to be the man my wife married.
I used to be schitzophrenic, but we're O.K. now
Last edited by john02fxdl; 03-23-2009 at 09:41 PM. Reason: Forgot one last bit of info.
john02fxdl is offline   Reply With Quote
Old 03-23-2009, 09:40 PM   #13
crapy67
White wall terror
crapy67's Avatar
I have motor, tranny, and body poly mounts in my Nova and I have no squeaking at all. The energy suspension mounts in my opinion are far superior then the factory mounts, With no flex at all. Its a very solid mount but not as harsh as a true solid mount. There great for the performance application.
Old 03-23-2009, 10:37 PM   #14
SactoJim
SactoJim's Avatar
Best way to see if it's broke or not is put the truck in a forward gear and give it gas while holding the brake.......if you blip the throttle back and forth, you will feel the motor slam back down if the mount is broken......usually it's the driver's side that gives up.
- supercharged 383
- 4 wheel discs
My Build Thread
Old 03-24-2009, 07:33 AM   #15
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
Hawker7 since you asked, I have a set of those, in Black New in the Box I Didn't need them. I will Sell them to you for $60.00 shipped If you want them.. Part# Prothane Motion Control 7-509BL
Let me know if your interested I have no use for them...
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 03-24-2009, 09:43 AM   #16
americanmusc1e
americanmusc1e's Avatar
you may want to modify the mounts depending on the style so you can remove them without taking the motor out (usually you have to cut the bottom off so you can access the bottom motor bolt with a wrench) the mounts I bought from carquest were like that I don't know about the NAPA mounts
has anyone else done this?????
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
