Old 03-23-2009, 04:22 PM   #1
slow72
slow72's Avatar
67-72 Drop Spindles
Hey everyone,
I'm looking for some 3' drop spindles for my 72 GMC LWB with disc brakes. Does someone make these? Or do i need to get 73-87 spindles and change ball joints and outer tie rods?
As an added issue i'm in Canada so shipping from places like summit would kill me. Thanks for your help!
1972 GMC LWB, 250, 4sp
2010 GMC Sierra 6.6 CCSB
slow72 is offline   Reply With Quote
Old 03-23-2009, 04:40 PM   #2
au03z71
au03z71's Avatar
Re: 67-72 Drop Spindles
I've only seen 2.5" drop spindles... They might make a 3" but I don't know where.
au03z71 is offline   Reply With Quote
Old 03-23-2009, 04:55 PM   #3
Shane
Shane's Avatar
You can use '73 and up and they are available in a 3" drop ... but you will have to change the ball joints and tie-rod ends.
Shane is offline   Reply With Quote
Old 03-23-2009, 11:27 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Shane is correct. To add to that, keep in mind 3" spindles will cause conflicts if you plan to run 15" wheels "in most cases".
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-24-2009, 07:00 PM   #5
slow72
slow72's Avatar
Is that because the rim will rub the lower ball joint?
SO what's the easiest way in your opinions to get a 5"-7" static drop? Keeping in mind i've got leafs in the rear and i can use a flip kit (5") and lowering shackles (2").
Old 03-24-2009, 07:31 PM   #6
gintaras
I have the same questions, I started a post on this page, but no replies yet.. I guess you just answered my question about the rear though.. I have coil springs in the rear
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 03-25-2009, 05:51 PM   #7
7two
7two's Avatar
Belltech offers a 3" spindle for your 72. Like stated you will need a 16" wheel to clear lower control arm. I have the spindles on my 72
7two is offline   Reply With Quote
Old 03-25-2009, 11:20 PM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Using "some" 3" spindles and certain 15" wheels, you will have problems with the rims hitting the A-arms.
It has been discussed that narrow 15 Rallies don't cause a problem, and certain spindles are more prone to rub than others.
This usually only causes a problem at hard left or hard right turns. You can mod your A-arms to clear, or add an adjustable steering stop.
The best solution I have found is a large diameter wheel...
Articles-
"Refining Sierra"
Old 03-26-2009, 10:36 AM   #9
SCOTI
SCOTI's Avatar
The 'outer' lip area of the lower a-arm directly adjacent to the BJ area does need to be trimmed for clearance (the wheel weights will hit). Other than that they fit.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-26-2009, 05:06 PM   #10
slow72
slow72's Avatar
Well i was hoping to keep my 15x8 rally wheels so i guess 3" spindles are out. Maybe 2.5" spindles and a 2" spring? Or DJM makes a lower control arm that will lower it 3". How do drop springs ride?
Old 03-27-2009, 02:16 PM   #11
SevenOne
SevenOne's Avatar
"(the wheel weights will hit)"
Flat stick-on weights that go on the inner side of wheel might help out in that situation.Hope it helps
SevenOne is offline   Reply With Quote
Old 03-27-2009, 02:21 PM   #12
Ont67shortbox
I have the ECE 2 1/2 drop spindles and 2 inch drop springs and have clearance on my 15x7 rallys if that helps any
Ont67shortbox is offline   Reply With Quote
Old 03-27-2009, 02:30 PM   #13
SCOTI
SCOTI's Avatar
The wheel still rubs the a-arm which is not desirable IMO so the a-arm lip requires trimming.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
