03-23-2009, 06:15 PM | #1 |
front allignment data
Anyone got data for front allignment on a 67 stepside. Smallblock engine and 1" lowering sping+ 2,5" drop spindles? Camber, caster and toe-in
67 c10 Short Step 350/th400 daily driver 69 Camaro work in progress |
03-23-2009, 07:27 PM | #2 |
sharp as a marble
Re: front allignment data
I would want:
0 degrees camber +- .5 degrees negative caster: as much + as you can get toe 1/8" toe in I posted recently that when I put drop spindles in my 69, I put it on my alignment machine, and was looking for the above. What I think you want to do is is to get the truck on an alignment machine, get it set up and do a caster sweep, just to see what you have BEFORE adjusting anything. Then try and get 0 degrees Camber. After that get as much positive caster as you can. If you drive on the same side of the road as we do in the USA, you would want .5 degrees more caster in the right front wheel to compensate for the crown in the road. If you drive on the opposite side then the reverse. Last edited by cparman; 03-23-2009 at 07:28 PM. |
03-24-2009, 02:09 AM | #3 |
Thank you very much for quick reply.. Great forum!
03-24-2009, 03:23 PM | #4 |
Restoration Virgin!
Hey cparman,
would this work for a 68 lowered 2.5" in front with spindles with a 350sbc????
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present Last edited by gcburdic; 03-24-2009 at 03:24 PM. |
