powdercoater
Ign cyl
Lost the keys to the ign,any easy ideas on how to get the ign cyl out w/o
having a key to turn it while pushing in on the release pin thx scott |
![]() Join Date: Jul 2008
Re: Ign cyl
Just come here to Detroit and ask any guy on any given corner and I'm sure they can help you out...
![]() Seriously though, I'm assuming you're avoiding calling a locksmith? |
The Older Generation
Re: Ign cyl
Take the passenger side door lock out and take it to a locksmith. There should be a code # stamped into the door lock and he can make a key from that code # that will fit the ignition. If you don't have a locksmith close you can PM me the code number and I will make a key and send it to you. The cost would be 5 bucks shipped.... The code number would be similar to the one in the picture. This works only if the locks are are original or were all replaced at the same time. If you have a locksmith come to your place and make a key it will probably be $45 minimum. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-23-2009 at 08:47 PM. |
#4 | |
powdercoater
Re: Ign cyl
i did a frame up restro on this truck back in 97 and all the cyl's were replaced at the same time.this truck has been in storage for the last 5 years. i have a new ign cyl and switch already that i got from my ac/delco dist for 23.00. i will ck my door cyl this weekend and let you know,otherwise i will just drill out the ign cyl so i can remove it from the bezel scott |
#5 | |
Re: Ign cyl
LockDoc
