Old 03-23-2009, 09:50 PM   #1
3quartertime
My Mistress the Sea
3quartertime's Avatar
Steering gear box compatability
My 71 K20 power steering gearbox is needing replace super bad...
I've found two gear boxes locally. One from a 79 K10 and the other from a 97 GMC Z71 4X4.
Anyone know if both or either of the boxes are compatible. I'll make a box to box comparison when I go see them, but gas ain't cheap so I was wanting to get an idea before I go...
Thanks!!!
,,,they'd look alot better as beer cans...
'71 K20 350/350 Rusty but trusty... gone
'70 C20... gone
'88 K1500... gone
'90 C1500... gone
'91 C2500... gone
'95 C3500 6.5L Dually love this one!...
3quartertime is offline   Reply With Quote
Old 03-23-2009, 09:58 PM   #2
Sammy
Re: Steering gear box compatability
Can't help you with that but might be safer to rebuild yours. Kits are available.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 03-23-2009, 10:00 PM   #3
see ten
WTB this ad
see ten's Avatar
Can't say off the top of my head...If I had to put money on one I'd go with the 79. I know on 2wd models people generally say that they'll bolt on all the way up to 86ish. I think the only issue is after a certain year the fittings for the lines are metric instead of standard. You might try posting this same question in the 4x4 section if you don't get a quick response here.
see ten is offline   Reply With Quote
