Old 03-23-2009, 09:59 PM   #1
Knothead
Knothead's Avatar
Gas Tank Fillers?
What are some options? Bed Fill & Side Fill or ?
Knothead is offline   Reply With Quote
Old 03-24-2009, 07:04 AM   #2
renegade6
Re: Gas Tank Fillers?
I am wondering that same thing.
I'm thinking about going with a side fill on towards the rear of the fender. I don't like the idea of having to climb up into the bed to fill the tank.
Brandon
63 Biscayne https://www.pro-touring.com/threads/90718-63-Biscayne
57 Chevy Truck (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=321380
72 K20 Long bed stepside (wife's)
72 K20 Long bed 396 (flip or keep...?)
The latest build: http://67-72chevytrucks.com/vboard/s...76#post8438476
renegade6 is offline   Reply With Quote
Old 03-24-2009, 12:30 PM   #3
OrrieG
OrrieG's Avatar
I am going to put mine next to the driver rear stake pocket on the inside. I got a tank with a side discharge. I have pictures of one that was put in the stake pocket with boat style flush cap, but you have to cut up the lower rear cross brace more than I like. Like you I don't want to crawl in the bed with my bad knees and drag the hose across the bed side and tailgate. another option is side door, I just did not want that.
OrrieG is offline   Reply With Quote
Old 03-24-2009, 07:14 PM   #4
renegade6
I think with a fleetside you have some more options.
Brandon
Old 03-24-2009, 07:57 PM   #5
sighlurr
______________
sighlurr's Avatar
A few interesting ideas from another thread:
http://67-72chevytrucks.com/vboard/s...ht=fuel+filler
sighlurr is offline   Reply With Quote
Old 03-25-2009, 06:05 PM   #6
Knothead
Knothead's Avatar
Thats what I"m trying to figure out, where can you hide it on a short step? Like Orrie pointed out, dragging the hose into the bed will become a pain. Then there is the problem if you have a load in the bed and need to fuel up!?
Old 03-25-2009, 06:38 PM   #7
renegade6
What about inside of the fender?
Brandon
Old 03-25-2009, 06:45 PM   #8
Knothead
Knothead's Avatar
That's kinda where im leaning , Would love to see some pics!
Old 03-27-2009, 03:09 AM   #9
BlueBowtie
BlueBowtie's Avatar
I did a rear filler neck right under the bed, since I have a rear mounted tank, and it's hidden.
Here's some pics.
I built a custom bumper, made a place for the tag to go, then I went to the junk yard and got a flip down license plate mount.
Although, my truck is on a '75 chevy frame, and my body isn't sitting right down on the frame.
http://www.cardomain.com/ride/3110793
1951 3100 RCSB
2000 K2500 CCSB
BlueBowtie is offline   Reply With Quote
Old 03-27-2009, 10:09 AM   #10
mylow53
mylow53's Avatar
i like the bed fill my self it's just how far you need to lean over to use it that seems to be the problem.
Greg
1953 chevy 1/2 ton 5 window, chevy 350 330 horse 700r tranz, lowering spindels mustang 2 frount. ford 9", airbags on 4 corners . purchased in 1983 for $325 while in high school
http://67-72chevytrucks.com/vboard/s...=215079&page=5
mylow53 is offline   Reply With Quote
Old 03-28-2009, 12:36 AM   #11
OrrieG
OrrieG's Avatar
some more ideas, I like the 8th post in the first thread:
http://67-72chevytrucks.com/vboard/s....php?p=3156893
Old 03-28-2009, 01:29 AM   #12
sgtusmc
sgtusmc's Avatar
Yeah that's a very slick one.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 03-28-2009, 09:07 AM   #13
smittys50
smittys50's Avatar
i went with a bed fill on my 50. its ok until you are at the gas station and gas spills all over the wood bed because the gas nozzle had some gas left in it from the previous user.
smittys50 is offline   Reply With Quote
Old 02-12-2015, 05:47 PM   #14
57chevyman
57chevyman's Avatar
Here's some pics.
you got the filler neck below the rear sill? what tank did you use? im using a universal mustang tank from tanks inc, and with the tank on the bottom rail of the frame, the filler needs to go straight thru the rear sill.
Frank
1957 Chevy 3100
2000 Silverado z71 SOLD
2012 Ram 1500 Quad Cab
1992 International 4700
57chevyman is offline   Reply With Quote
Old 02-12-2015, 06:20 PM   #15
octanejunkie
octanejunkie's Avatar
I cut a fill door into the rear fender. I posted a thread about it here.
Déjà vu. It's that feeling you get when you hit your thumb with the hammer a second time
'59 Chevy 3100 Stepside
octanejunkie is offline   Reply With Quote
Old 02-12-2015, 07:17 PM   #16
57chevyman
57chevyman's Avatar
Nice job on that fuel door. I really want to keep the fenders clean, and I don't really want to have the fill inside the bed. Within the next couple of weeks I should have my tank and filler installed. My tank is only 7 inches top to bottom , so I can mount it on the bottom of the rail with no issues with the tank hanging too low.
Frank
1957 Chevy 3100
Old 02-12-2015, 07:24 PM   #17
57chevyman
57chevyman's Avatar
My plan is to mount this jeep bezel in the rear sill. I have to add about two inches of metal below the sill in the middle to create a large enough surface to mount the bezel and also mount the flip down license plate bracket on the bottom of the extra strip of metal I will add
Frank
1957 Chevy 3100
Old 02-12-2015, 07:35 PM   #18
Speedbumpauto
Speedbumpauto's Avatar
The rear of the rear fender makes it less noticeable but still easy to get to.
Speedbumpauto is offline   Reply With Quote
Old 02-12-2015, 07:45 PM   #19
57chevyman
57chevyman's Avatar
Looks great.
Frank
1957 Chevy 3100
Old 02-13-2015, 07:50 PM   #20
57chevyman
57chevyman's Avatar
Thinking a rectangular gas filler bezel would be easier / work better. Anyone have a suggestion ? I want it to look more finished than just cutting a hole or notching the rear sill...
Found this on the Internet.....
Frank
1957 Chevy 3100
Old 02-13-2015, 08:22 PM   #21
octanejunkie
Would something like this work?
http://www.ebay.com/itm/Jeep-YJ-87-9...3D321408641996
Old 02-13-2015, 08:24 PM   #22
Dustint
I've seen some custom applications use pop up motorcycle gas cap and neck bungs, weld them in and they are flush with the surface. Plan on doing this unless I end up rear mounting tank and hiding it behind the plate or something like that.
https://www.kindigit.com/store.php
some good pictures here, bout half way down. First time I saw it was on one of their cars.
Dustint is offline   Reply With Quote
Old 02-13-2015, 08:28 PM   #23
57chevyman
57chevyman's Avatar
Originally Posted by octanejunkie View Post
I thought about that ..... My brother has a '79 CJ..... The gas filler neck goes straight in instead of on an angle downward ..... Won't work for me
Don't know why picture uploaded sideways
Frank
1957 Chevy 3100
Old 02-13-2015, 08:43 PM   #24
57chevyman
57chevyman's Avatar
I am mounting behind the plate .... Just thinking of how to make it looked "finished". It's gonna be hidden behind license plate unless I'm fueling up or showing to someone ...
I could also just cut a round hole and finish the edge with a rubber grommet .
Thought of using the round jeep tj bezel too.
Frank
1957 Chevy 3100
Old 02-13-2015, 08:53 PM   #25
57chevyman
57chevyman's Avatar
maybe im making this more complicated than it needs to be. as far is i can tell right now, my filler cap is going to have to be in the middle of my rear sill.
what if i cut a hole with a hole saw and put in a grommet like this.... the hole would need to be big enough to be able to grip the cap.. unless i got one of those old school caps with the tabs on them..
Frank
1957 Chevy 3100
