Old 03-24-2009, 12:39 AM   #1
jnesto
Question 1987 k10 brakes on a 66 c10
i just got these brakes from pick apart and i was wondering if anybody can show me some pick or show me a diagram of how the brake tubing would run starting from the perportioning valve, which goes where. I would appreciated if somebody showed me. Thanks
jnesto is offline   Reply With Quote
Old 03-24-2009, 12:48 AM   #2
Captainfab
60-66 Nut
Re: 1987 k10 brakes on a 66 c10
Are you converting to discs on the front as well? are you using the '87 K10 master cylinder and booster?
Old 03-24-2009, 09:52 PM   #3
jnesto
yes im going disc in front, and im using the master cylinder and booster from the 87 k10 I also got the callipers from the 87. im disc brakes in front and the 66 drums in the back. i need to which way the tubing goes from the perportioning valve.
Old 03-25-2009, 01:08 AM   #4
Captainfab
60-66 Nut
Here's a pic of one another member just did....see if this helps you out.
http://www.67-72chevytrucks.com/vboa...&postcount=117
