Old 03-24-2009, 01:06 AM   #1
Mikey's68
Cool Steering column
I'm thinking about changing my stock steering column with a tilt column. I heard you can can use one out of a Chevy van. Does anyone have a suggestion on what type or year of van i can use. I have plenty of recking yards around. Thanks
Mikey's68 is offline   Reply With Quote
Old 03-24-2009, 01:18 AM   #2
67/72junkie
Re: Steering column
any chevy van up until around 80.Not sure exactly what year they put ignition switch on the column but as long as the column doesn't have the ignition switch it will work with a few mods.Also some motor homes have the same van column.
67/72junkie is offline   Reply With Quote
Old 03-24-2009, 09:42 AM   #3
Mikey's68
Re: Steering column
Sounds great! Thanks Junkie
Old 03-24-2009, 09:58 AM   #4
big_al_71
big_al_71's Avatar
Re: Steering column
I bought opne from classic perform and saved me a ton of headaches. Specially since in Miami you have zero chance of finding a used column of a van.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-24-2009, 10:31 AM   #5
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Steering column
Or you can buy one with all mods. done ready to install from me. Check link below
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 03-24-2009, 04:22 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Steering column
72 - 81 GM vans
Early ones look dead on right for the trucks, the turn signal switch is a direct plut in, the shifter arm is long like the truck ones, the perndle has the right font.
The later ones have a smaller shifter arem which is cool if you wana run a small wheel.
Old 03-24-2009, 06:32 PM   #7
72BLUZ
72BLUZ's Avatar
Re: Steering column
have you checked the ididit web site
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream.
It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan
72BLUZ is offline   Reply With Quote
Old 03-24-2009, 07:07 PM   #8
Longhorn Man
Re: Steering column
$25 to $45 for a van unit that looks stock or quite a bit more for one that still needs more parts to complete.
Old 03-24-2009, 07:59 PM   #9
cparman
sharp as a marble
Re: Steering column
I put an IDIDIT column in a Blazer for a customer, and it was ok, but not an OE tilt column. The fit and finish was perfect, but the shift indicator was not lit, and a bit hokey. For my money I would spend the bucks and get a factory tilt!
Longhorn man must have worked really hard today. His spelling looks like I typed it! haha
Support the guy who posted above and let him do you an OE column
cparman is offline   Reply With Quote
