03-24-2009, 08:49 AM | #1 |
Steering Column Change
My Uncle has a 1972 Chevy C10 and he wants to buy a replacement chrome steering column from LMC Truck Parts with tilt wheel.
Questions: 1) has anyone purchased a replacement column from LMC and how was it? 2) how difficult is the switch out. Is it fairly straight forward? Your thoughts? Lar Last edited by larry horne; 03-24-2009 at 08:50 AM. Reason: spelling |
03-24-2009, 12:22 PM | #2 |
Re: Steering Column Change
Can't answer number 1 question - but the other one...
Very simple... 1. Disconnect electrical at the base of the steering column -Turn Signal Switch and Neutral Safety Switch 2. Unbolt the column from the dash/firewall 3. Remove column connection at ragjoint and pull wheel/column into the cab Depending on what you get with the column - it will likely just bolt in the same way using the reverse steps above (never seen the LMC column)... |
