Old 03-24-2009, 11:24 AM   #1
VA72C10
VA72C10
VA72C10's Avatar
Looking to build my dream Blazer
I deleted the 2wd ad that I put in the forum because of all the information you guys have given me. Through your suggestions it makes much more sense to me to find a 4x4 with a good/great tub on it and do the conversion. I plan to bag it and am considering a Porterbilt front dropmember and a 4-link rear now so might as well go with a cheaper start and from what I understand a better way to go lower...
Budget is up to 10K for a project that's already converted and set up for bags, probably honestly looking to find one in the 2-5K range with a great body and then build it the way I want from there. I will consider the entire US as a search area because I assume the best tubs are going to be out west of course. Would like an A/C truck but I could add that (Vintage/Old Air) and prefer tilt and tach but I have both of those already Would also prefer original seating but that is up to debate...might go with the new tahoe front and third rows...
Thanks for all the information so far and I will be picking your brains some more if you don't mind...maybe I can return the favor with parts I pull off my blazer/jimmy when I find it.
Below are just a few of the "inspiration" pictures I've saved for my build...Plan on a 67-68 front, cowl hood, 20's all around with a staggered (wider) width rear, leather interior, nice stereo molded in with fiberglass panels on the sides, strong 350/383/400SB with 700R4, Tilt column, Tach Dash or Custom dash (still deciding) Airbag suspension with Dropmember, 4-link, sway bars, etc etc etc....
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-24-2009, 01:29 PM   #2
teamradrz1
teamradrz1's Avatar
Re: Want to buy a nice 4x4 K5 Blazer/Jimmy 69-72
that last one in flat black is AWESOME!
1971 Chevy Blazer CST 4X4
2012 Camaro 2SS/RS
2007 Avalanche 4X4
teamradrz1 is offline   Reply With Quote
Old 03-24-2009, 01:51 PM   #3
VA72C10
VA72C10
VA72C10's Avatar
That's the Fessler one...probably a 100K vehicle...here it is finished
And the link http://www.feslerbuilt.com/1967Feslerblazer.htm
Old 03-24-2009, 02:16 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
I the Fesler rig was for sale at $200K.
http://www.dupontregistry.com/autos/...?itemid=576189
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 03-24-2009, 02:33 PM   #5
Liz
Catchy title goes here..
Liz's Avatar
http://67-72chevytrucks.com/vboard/c...cat.php?cat=19
Liz is offline   Reply With Quote
Old 03-24-2009, 04:40 PM   #6
VA72C10
VA72C10
VA72C10's Avatar
Re: Looking to build my dream Blazer
Thanks for opening this back up Liz...
Hey, I was only off by 100K on the fesler blazer
Old 03-24-2009, 04:42 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
Has anyone modified a stock top to fit a raked back windshield? I really like that look but figure that's getting into a major amount of work and $$$ to make that look right with a top. I plan on mainly driving this during cruising season (about 6-8 months here) but will not always have garage space for it so It'll have to have a top.
Old 03-24-2009, 06:12 PM   #8
bouncytruck
SKINNY TIRES RULE!
Have you seen Brad2's fixed roof project? http://67-72chevytrucks.com/vboard/s...d.php?t=328161
bouncytruck 1972 K5
Old 03-24-2009, 09:22 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
I have...I guess I should clarify to say that I would love to run it topless completely like 5150's AWESOME blazer, but plan on using it as a backup family hauler so it'll need a top and A/C and heat. But, I'd like to modify the stock removable top to fit a raked windshield...I will run it w/out a top from spring through fall but want to be able to put a top on if it gets kicked out of the garage for me to work on home remodeling projects.
Old 03-25-2009, 04:22 AM   #10
OARNGESI
OARNGESI's Avatar
Those are some great inspiration pics hope you can find a nice one to build i think we all want a 2wd blazer i know i do
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 03-25-2009, 07:26 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
Here's another one to drool on. Forum member bagged74's 72.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-25-2009, 08:01 AM   #12
FuelCellGuy
FUEL CELL GURU
FuelCellGuy's Avatar
http://www.67-72chevytrucks.com/vboa...d.php?t=200851
Looks like I am gonna have to sell mine. $7500. I'll post all the details later. Mark
FuelCellGuy is offline   Reply With Quote
Old 03-25-2009, 12:15 PM   #13
FuelCellGuy
FUEL CELL GURU
Ok, its got a 350 carb with 5-speed standard shift, 3:08 gears in a rebuilt rear-end with big drum brake upgrade. It has new 20" x 8.5" Boss whells with Goodyear rubber (0 miles). It is a 4x4 conversion however, it is on a 2WD frame. Frame has a minor c-notch. It is currently dropped with drop springs. Add air bags and it will lay on the control arms, similar to picture above of my old truck. It does have a brand new Vintage Air unit mounted behind dash but not hooked up. It has a full set of Autometer Phantom gauges with electronic speedo and sender. All the gauges are electric. The body is in good shape, rocker boxes look solid and feel solid. Door corner showing a few small bubbles. The firewall had some rust at the windshield corners but has been cut out and fixed. Firewall has been smoothed. The grill is a GM original in great shape. The engine has late model pulley and accessory setup. Of course, it has on of my 18 gallon aluminum fuel cells in it. Interior is in good shape maybe a bit outdated but fine for a cruiser (velour). Top is in great shape. Please post any other questions you may have. Thanks, Mark
Old 03-25-2009, 01:16 PM   #14
VA72C10
VA72C10
VA72C10's Avatar
Sounds pretty good to me...I checked out the post...can I get some more pictures? Details on vintage air setup (WHat controller and what needed to complete the installation) Do you have any contacts w/ transporting it or would I need to work that out? Discs or drums in the front? Details on the motor build and what tranny,posi? rear. Thanks!
pm sent as well
Old 03-25-2009, 10:37 PM   #15
OARNGESI
OARNGESI's Avatar
That looks like a nice one for you
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 04-07-2009, 04:42 PM   #16
VA72C10
VA72C10
VA72C10's Avatar
Looking at a 72 Jimmy 4X4 local to me right now...rusty and rough but the price is right
Old 04-08-2009, 04:46 AM   #17
OARNGESI
OARNGESI's Avatar
Good luck with it
70 SWB STEPSIDE
70 BLAZER
09 challenger
Old 04-08-2009, 05:30 PM   #18
bigblazerboy
bigblazerboy's Avatar
the camo one?
bigblazerboy is offline   Reply With Quote
Old 04-08-2009, 05:46 PM   #19
VA72C10
VA72C10
VA72C10's Avatar
Originally Posted by bigblazerboy View Post
the camo one?
Yeah, did you look at that one? It will need floors, rockers, work on bedsides, fixing the hatch, etc....
Old 04-09-2009, 12:39 AM   #20
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Did you get a blazer yet?
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 04-09-2009, 12:42 AM   #21
VA72C10
VA72C10
VA72C10's Avatar
Not yet...still looking. I am sure if I am patient I will find a deal on one so I'm not jumping into anything.
Old 04-09-2009, 11:29 AM   #22
bigblazerboy
i have not gone to look at it but did you get any pictures of the bad spots? would he go any lower on price?
Old 04-09-2009, 02:12 PM   #23
VA72C10
VA72C10
VA72C10's Avatar
I didn't get any pics...he wasn't willing to go down much...
Old 04-09-2009, 04:28 PM   #24
jamie72
jamie72's Avatar
sent you an e-mail...
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
Old 04-09-2009, 08:01 PM   #25
bigblazerboy
oh i didnt really like that one all too much. theres one i gotta look at jsut havent haid time
