Old 03-24-2009, 12:15 PM   #1
rgreathouse
SWB to LWB HELP!!!
i started this thread asking a lot of questions about how to shortenen a lwb truck
http://67-72chevytrucks.com/vboard/s...d.php?t=334138
i didnt get a ton of help and i really just need to verify where to cut the bed and the best way to shorten the frame.
here they cut the frame right behind the cab(anything wrong with this?)
http://www.customclassictrucks.com/t...ech/index.html
here is lfds build he cuts under the cab. he shortens the bed 12 in front of tires and 8 in the rear.20" total.
http://67-72chevytrucks.com/vboard/s...Lowbuck&page=8
whereass in this article they cut 6" out of rear section and 12" out of front section. 18" total.
http://www.truckinweb.com/tech/body/...bed/index.html
so my question is what is the proper way to do this? cut under cab or behind cab? is measuring 83/4" from front stake pocket and cutting out 12" from bed and measuring 83/4 from rear stake pocket and cutting out 8" the correct way to do it? (this is something ive decided to do so please no input on how i shouldnt do it or i am ruining a LWB truck)
any help appreciated
thank you
1972 c10,2wd,long bed,250,4spd---->
1972 SWB Fleetside 4x4 12v Cummins build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=513791
rgreathouse is offline   Reply With Quote
Old 03-24-2009, 12:35 PM   #2
Willys47
Willys47's Avatar
Re: SWB to LWB HELP!!!
I don't think there is a right spot,as long as you cut were the frame is strait under or right behind the cab.Just keep your cuts away from the arched sections of the frame. I cut mine were the cab mounts are and the center cross member was located so I could cut out some rust that had pited the frame from mud and salt sitting from past winter driving. I just moved my crosss member forward 12 inches and bolted it back in
I was hooked on these trucks since 1982 when I drove my budys fathers 1968 Custum GMC 396 automatic dana 60 rear with a power lock diff what a ride more fun then we will we can ever tell!!
Willys47 is offline   Reply With Quote
Old 03-24-2009, 03:00 PM   #3
monte0185
monte0185's Avatar
I have seen this done a couple times and i think most people prefer behind the cab so you do not have to move the cab mounts. But in reality its a personal choice as this is fabrication and you have to do what you are able and comfortable with.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 03-24-2009, 05:06 PM   #4
rgreathouse
ok, well i would prefer to do it behind the cab so that i do not have to remove my cab.although i am wondering where exactly i should cut
Old 03-25-2009, 10:48 PM   #5
Brad
Out of the carpool lane.
Brad's Avatar
Most on here will tell you to cut 8" off the rear- don't do it! Try 6" first and then cut slightly more if needed. Cutting 8" will put you too close to the bed mount holes and possibly cut into them.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 03-26-2009, 04:48 AM   #6
the lights
the lights's Avatar
on mine i cut the frame where the first bed cross brace bracket was. about 3/4 to 1" from the front rivet hole. if that helps.
the lights is offline   Reply With Quote
Old 03-26-2009, 04:07 PM   #7
rgreathouse
so is there any reason not to cut the frame right behind the cab right after the carier bearing crossmember? this is a leaf spring truck.
Old 03-26-2009, 04:10 PM   #8
Willys47
Willys47's Avatar
I don't know of any
Old 03-27-2009, 01:35 PM   #9
CheyenneShop
CheyenneShop's Avatar
This is the one that I am using, but if you don't want to lift cab - use LFD thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
72 Cheyenne shorty "CheyLow"
72 3/4 long 4X4
69 SWB "Prospector"
68 C/10 shorty - "Picacho" http://67-72chevytrucks.com/vboard/s...d.php?t=428379 sold to "93redsled"
Have you heard about C10 Talk? C10 Talk is a podcast all about C10 Trucks, the builders, the vendors, and most importantly the C10 Community. Check us out online at www.c10talk.com
CheyenneShop is offline   Reply With Quote
Old 03-27-2009, 11:31 PM   #10
magsnubby
magsnubby's Avatar
I've cut down a couple of older leaf spring trucks. It's not that hard on a leaf spring truck. I cut 'em behind the cab. I cut it about an inch longer than trimmed it up until it was the exact length then spot welded it back together, measured it, then welded it back together.
magsnubby is offline   Reply With Quote
Old 04-05-2009, 10:51 AM   #11
rgreathouse
well ive started cutting so stay tuned
Old 04-05-2009, 11:29 AM   #12
Willys47
Willys47's Avatar
