harness wire hiding
i'm installing a new wire harness and wanted to know what everyone uses for cable management. the kit (ez wiring) came with zip ties but i want to use some kind of cable wrap. any ideas?
1972 Chevy C10 Long Bed 454 Big Block Turbo 400 3 Speed Dual Flowmaster Edelbrock 750 Carb Power Steering Disc front brakes Drum rear brakes B&M Floor Shifter |
Re: harness wire hiding
I am also interesting in seeinng what people have done, I also have a wiring harness kit sitting and ready for install. I did buy some of those rubber/stainless Umpco "P" clamps on linr. I planned on running the wiring harness, then wrapping it in black split wire loom and using the umpco p clamps to attach it to the frame.
What has everyone else done???
1972 K5 Build - plans - LS3-6L80e-One Tons..... 1971 CREWMAX Build.....at body shop for couple more years ![]() |
VA72C10
![]() Join Date: Mar 2008
Not much help here, but There's a corrogated plastic split loom which comes in black, colors, and a chrome version, and then the "fabric" style wraps...I think the main thing is to try to hide the wires as much as possible and use good connectors (heat shrink or similar)
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
My truck was completely rewired from front to back by one of techs all the wires were wrapped, heat shrinked and he used alot of cable clamps. Look at the picts below hopefully it will give you an idea. These are some picts that I have in my computer in my office.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 03-24-2009 at 08:35 PM. |
Freedom isn't Free
classic industries sells rolls of the original style wire wrap - I used it this weekend - it's slick as hell.
Old member
I like the plastic wire wrap that is split. It's easy to use and it looks nice.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Has anyone found the cheapest place to buy the split loom, and what different sizes are you guys using?? Are you guys using the plastic tee's?
