03-24-2009, 03:39 PM | #1 |
water problem
im new on here and im restoring my 72 C10 but im having a problem with water getting in from in between the top of my cab and the door. Is there anything that i can do to stop the leaking. Its starting to rust out the bottom of my doors. please help
03-24-2009, 04:16 PM | #2 |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: water problem
check door alignment and replace the rubber. Best i can tell ya.
Good Luck!
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
03-24-2009, 05:28 PM | #3 |
weatherstripping and water problem
I'm restoring my 72 C10 and water keeps leaking in between the top on the door and the cab. I have weatherstripping around door frame in the cab where the groove for it is but there is no groove for it on the door. I was wondering if there were two sets of weatherstripping that go in the cab and each door, or there was weatherstripping or something that also goes on the door itself that will keep water from getting in and running down and settling at the bottom of my door and sill. It is starting to rust.Please help.
03-24-2009, 06:08 PM | #4 |
Re: weatherstripping and water problem
TTT to keep this thread alive. Someone will be able to help. Good luck!
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
03-24-2009, 06:19 PM | #5 |
Between Trucks...
Is that new weather stripping? I'm running the press on type from GMC Paul's, no leaks. Does make the doors a little harder to shut and I'm too lazy to readjust the door strikers.
Beat it to fit, Paint it to match... |
03-24-2009, 06:37 PM | #6 |
Active Member
Re: water problem
Welcome to the forum.
First, I'd make sure it's not coming from the rain gutter area. These trucks are notorious for rusting there and because it's unseen it wreaks havoc before you know what's happening. Check carefully on the upper cab corners above the windshield area for damage. Hopefully it's not where it's coming from because they don't make roof top patch panels. Otherwise, as Jhart mentioned, check the door gaps and make sure you have some good rubber on them. I used the GMCPauls push on type of seals and has worked great on my 68. |
03-24-2009, 06:45 PM | #7 |
Active Member
I guess this is a double post. I answered on your previus post.
If you need to add more info you can edit your posts by clicking on the "edit" function afer you submit. Or you can have one of the moderators delete. |
03-24-2009, 07:21 PM | #8 |
the weatherstripping around the cab is new. Im just wondering if there is anything that i can put on the door itself to stop the water from coming in
03-24-2009, 07:26 PM | #9 |
Active Member
As was mentioned, you may have to adjust your doors. If that doesn't work, I guess you can rig something up but I don't know of any type of seal that is specifically made for the door.
03-24-2009, 07:40 PM | #10 |
thanks for the help. I really appreciate it and this site
03-24-2009, 09:25 PM | #11 |
Hey Bskard, when I redone my truck I had to put my knees against the inside of the door and pull the top of the frame in to get it to seal off, it was slightly pushed out, it doesn't take much to get it to seal off, Hope this will help you out
03-24-2009, 11:43 PM | #12 |
This isn't by any means professional, but I've used camper tape to help seal up doors that kept leaking no matter what I did, you know the stuff you put on the bed of your truck before you put on the camper shell. It works, even if it isn't pretty:
http://www.doityourself.com/invt/0381863 |
03-25-2009, 08:53 AM | #13 |
Active Member
Re: water problem
Hey, Bskrd, just thought of something I used on my 69 to keep the rain out with window partially open. They were the stainless steel or chrome window visors. Not sure if it will help your situation, but may be worth a try. I bought mine at a local auto parts store but that was about 18 yrs ago...
GMCPauls, and other vendors on this forum sell them. http://www.gmcpauls.com/custom_accessories.htm "PN 134778 -67-72 Door Ventshade Stainless Steel door visor, clips to top outside of door to reduce wind noise, block sun and prevent rain entering when window partially down. Sold as a pair." |
