Old 03-24-2009, 05:06 PM   #1
gintaras
make it easy.. lowering a '72
Hey, i am fairly new here, I'd like a sportier and more agressive looking ride in my '72 LWB
I don't want to cut anything up at all, the truck only has 69k miles on it and is rust-free, so i want to keep everything reversible.
With that in mind, I think my only option is a mild drop, spindles and springs in front, flip kit in rear? or perhaps just springs in rear?
I would also like to still be able to haul things in the back, like furniture and such, as well as be able to tow a trailer.
So.. like the topic states, what is my best bet for this? Looking for a 4 or 5" drop up front, 6 in rear, maybe more if it is easily done.
Thanks!
2004 VW R32 450 HP money pit (faster than a Viper in the 1320 )
2001.5 VW Passat beater
1972 Custom Deluxe Highlander 69k miles and counting, all original, even the paint
gintaras is offline   Reply With Quote
Old 03-24-2009, 09:40 PM   #2
Rokcrln
Rokcrln's Avatar
Re: make it easy.. lowering a '72
Well if you want a bolt on kit that does not cut anything then I would look into ECE (Early Classic Ent) for drop spindles, springs up front and yes ether a flip kit that does not require welding on new spring perches or just DE-arched leaf springs. Talk to Stan and tell him Kevin from Winters told you to call and he can give you all the info you need to keep your truck reversible but cool in the mean time.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 03-24-2009, 09:52 PM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Kevin pretty well summed it up... contact ECE and they will hook you up. Stan is great to work with and definitely knows his stuff. Their prices will be a little higher than CPP but you will make up for it in customer service/satisfaction.
I wouldn't recommend going lower than 4.5/6 static drop on your truck. If you go lower than that I would just go with bags but since you're wanting to be able to remove the pieces stick with the static drop.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
