Old 03-24-2009, 06:05 PM   #1
69heavychevy
69heavychevy's Avatar
having hard time with the thumper cam
i was wondering if anyone here was running a thumper cam, #12-600-4 to be exact. i just got thorugh installing one in my truck but having trouble with the timing. i seem to have to retarded quite a bit to get it to even run right. if anyone is running this came what do they have their timing set to. im also open to any suggestions. oh yea i have a performer rpm, edelbrock 600cfm, headers, and 993 heads. thanks in advanced!
69heavychevy is offline   Reply With Quote
Old 03-24-2009, 10:16 PM   #2
69heavychevy
Re: having hard time with the thumper cam
anybody??
Old 03-24-2009, 11:17 PM   #3
shortbed70
shortbed70's Avatar
could be one tooth off on dizzy.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 03-24-2009, 11:36 PM   #4
69heavychevy
finally got it to run ok, have set at around 3 degress, any higher n i pretty much have to back out the idle screw completely. will mess with it some more 2morow
Old 03-24-2009, 11:37 PM   #5
vectorit
What?
vectorit's Avatar
Sounds 180 out.
Pop the #1 spark plug, and tap the starter till you hear compressed air rush out. turn the motor by hand (helps if you pull all plugs) with your balancer, till the TDC mark it on 0 with the tab.
Then pop the dizzy cap, your rotor should be pointed at the #1 plug terminal.
If it's not, then pull the dizzy out and rotate to its correct position.
Sounds silly, but it's a common mistake.
Thats my first guess.
Good luck!
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 03-24-2009, 11:59 PM   #6
69heavychevy
yea sounds silly, but i was wondering the same thing. when #1 cylinder is at tdc, is the marking on the cam gear supposed to be at 12 o'clock or 6 o'lock. ive seen both listed on different manuals
Old 03-25-2009, 12:06 AM   #7
faribran
... depends on how your distributor wires are placed on your dist. cap...
important thing is... does the rotor point close to the wire to #1 plug?
faribran is offline   Reply With Quote
Old 03-25-2009, 12:08 AM   #8
faribran
did u use a standard timing set? or one of the "multiple choice" ones?
Old 03-25-2009, 12:12 AM   #9
69heavychevy
standard timing set, n rotor was pointing towards the #1 cylinder.
Old 03-25-2009, 07:15 AM   #10
cdowns
cdowns's Avatar
most timing sets the cam is at 6 the crank at 12//for dizzy TDC must be on the compression stroke
Old 03-25-2009, 10:44 AM   #11
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
Im running the Mutha Thumpr in mine. It took a while to get the timing right. My harmonic balancer is off just a little. I had to check where TDC is on it first before I understood exactly where the timing was. Those cams are awesome but a pain in the ass when it comes to timing.
Scott Hammond
Lancaster, SC
1969 Chevy2005 Chevy Silverado Z71 72 Chevy 1972 SWB 454
If you don't live for something, then you'll die for nothing. www.xclusive-images.com
scott's69 is offline   Reply With Quote
Old 03-25-2009, 11:29 AM   #12
68Stepbed
68Stepbed's Avatar
Have you talked with CompCams about it? They have a tech help line. They designed the cam, so they might be able to help you more.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-25-2009, 11:52 AM   #13
71c10bbsuper
71c10bbsuper's Avatar
sounds like you have things right you should need about 10 degress btdc
if it is trying to idle to high with that i would be looking for a vacumn leak
the mark on the cam does not matter if it at 12 oclock or 6 oclock as long as
your rotor is pointing at #1 spark plug terminal when engine is at tdc on the compression stroke
71c10bbsuper is offline   Reply With Quote
Old 03-25-2009, 03:31 PM   #14
69heavychevy
interesting, i guess thats why u see the cam marking set at diff points depending what manuals u use. anyways i messed with her some more today n it seems to like it around 8 degrees btdc.
Old 03-25-2009, 07:01 PM   #15
scott's69
WORTHLESS CRUISERS
scott's69's Avatar
I had to fight spark knock when I nailed the throttle and running on when I switched it off. I went back and forth with the timing. Just find the sweet spot and dont worry about "manuals and instructions". The techs at Comp can help ya if ya need to. Good luck.
Scott Hammond
Lancaster, SC
