03-24-2009, 08:35 PM | #1 |
Jonny
What is This??
I found this under the suburban I am parting out and don't have a clue as to wht it is or does. It is attached to the axle housing and then has a lver system attached to what appears to be a regulator for the rear brakes. The line going in and out of it goes to the brakes.
Any clues? Is it worth pulling?
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
03-24-2009, 08:50 PM | #2 |
huh ???
Re: What is This??
Somebody else was just asking about one of those the other day.
http://67-72chevytrucks.com/vboard/s...d.php?t=334556 Chuck
90 Blazer Silverado 350w/ 700R4 and 32" Kelly's "I am a bomb technician. If you see me running try to keep up!" |
03-24-2009, 08:52 PM | #3 |
Re: What is This??
Looks like an load-based rear brake proportioner like the mid-80's toyota trucks used. it adjusts the amount of rear brake baised based on the load in the vehicle.
