5x5.5
Is there any way to make this bolt pattern work on our 5x5's?
yeller
Re: 5x5.5
not unless you drill your axles and rotors to accept the different pattern
EDIT: There may be adapters out there, but that will affect the width of the rim you can run....and some people swear against them.
Jeff 73-87.com 73-87.com Facebook page 73-87 cab corner 6x9 speaker brackets for sale 67-72 cab corner speaker brackets for sale 47-54 cab corner speaker brackets for sale Last edited by bigblock73; 03-24-2009 at 09:30 PM. |
Re: 5x5.5
What about a set of adapters to make a 5 x5.5 to fit?
Re: 5x5.5
Those adaptors are what he meant, problem is that they're about 1-2" thick so it can affect wheel choice. Also, some question strength/structural integrity..
thinair
![]() Join Date: Jun 2004
Re: 5x5.5
I've seen guys use these adapters on all sorts of high horsepower/torque applications with no problems.Tighten everything up like you are supposed to with new aluminum and all would be fine,especially if all you are doing is drivin on the street.
Happy to be here
![]() Join Date: Mar 2000
Re: 5x5.5
The cast adapters are junk. Just make sure if you do run adapters you use the machined billet or steel version.
Re: 5x5.5
Thanks guys... I found the wheels I want on craigslist, so I'm going to look into some decent adapters that aren't a mile wide.
| Bookmarks |
