Old 03-24-2009, 11:22 PM   #1
tim21391
tim21391's Avatar
Transmission oil cooler
do they even reproduce this i cant even find anything
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 03-24-2009, 11:36 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Transmission oil cooler
its inside your radiator. You can get the cooler seperately, but a new 4 row rad can be had for like 150 at auto zone, and a cooler alone with the labor to install it would be close to that, and you'd have an old rad still.
Old 03-25-2009, 01:26 PM   #3
tim21391
tim21391's Avatar
i only need the oil cooler.. radiator is fine... cant find any sites that sells these.. i got a new radiator support and dont wanna put a leaky cooler back on
Old 03-25-2009, 01:49 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Andy is saying that your trans cooler is inside the radiator. To replace it, the radiator has to be unsoldered and disassembled. He's saying it is likely cheaper to get a new radiator, which will come with new cooler inside of it.
If you have a cooler mounted externally from the radiator, it is an add on from an aftermarket source. In that case, Summit has literally hundreds to choose from depending on size and hose fitting configuration you want.
Old 03-25-2009, 02:43 PM   #5
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
...or you could just go to virtually any automotive supply house and buy a transmission cooler. Transdapt made the one that I am using. I just mounted it on the front side of my A/C condensor, which is in front of my 4-row core radiator. No, it hasn't overheated. I recommend it.
Member Nr. 2770
Old 03-25-2009, 03:13 PM   #6
Tx Firefighter
I've gotten several really high quality ones off of junked police cars at the local salvage yard. Just kick the grille out of it and there is usually a nice fat cooler ripe for the pluckin.
Old 03-25-2009, 03:15 PM   #7
El Jay
Gone to greener pastures
Here's a store bought aftermarket that was installed after the 4 speed was taken out & a TH350 was installed.
And, as Chevloray said, available just about anywheres.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-25-2009, 06:25 PM   #8
shooterpcb
are these external coolers plumbed to the radiator at all? or are they stand alone coolers with only the lines to the auto trans? Thanks
1968 C-10 2wd, short bed fleetside, 355 Chevy, TH350, 12 bolt pegleg, '81 Camaro cowl induction on hood(I don't like it, previous owner did it), 10" wide 15"wheels.
shooterpcb is offline   Reply With Quote
Old 03-25-2009, 06:40 PM   #9
tim21391
tim21391's Avatar
i mean like i have a thing mounted in front of my radiator that is on the passenger side.. its prolly like 10 inches long by like3-4 inches wide.. what is that?
Old 03-25-2009, 09:16 PM   #10
El Jay
Mine is a stand alone because the original radiator had no cooler in it.
I have seen, in one instance, where the guy decided to pull a trailer (with his car) and came out of the cooler in the radiator & then plumbed to an external cooler & then back to the transmission.
I don't know if it really helped or not. I just happened to be in a shop where the car was being worked on.
Is it plumbed to something? What?
Old 03-25-2009, 10:02 PM   #11
big_al_71
big_al_71's Avatar
I have a four row aluminum radiator without a cooler so we installed a B&M cooler on the core support. So far so good in the hot humid florida climate..
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 03-25-2009, 11:44 PM   #12
tim21391
tim21391's Avatar
ya it goes to the tranny because when i took it off i had tranny fluid come out...look between my passenger side blinker and my front license plate.... that would be the thing im looking for.........
and here is a better view
Old 03-25-2009, 11:45 PM   #13
tim21391
tim21391's Avatar
its bent and leaking so i dont want trans fluid getting on my freshly redone new radiator support..
Old 03-26-2009, 12:03 AM   #14
leddzepp
Moderator
leddzepp's Avatar
An auxiliary cooler should always be run in conjunction with the heat exchanger (cooler in the radiator). The heat exchanger works best because water dissipates heat better than air. This was told to me by a design engineer for GM.
leddzepp is offline   Reply With Quote
Old 03-26-2009, 07:06 PM   #15
tim21391
tim21391's Avatar
oh ic..anybody know where to find a new one of these in my pics?
Old 03-26-2009, 07:15 PM   #16
Sinister
Between Trucks...
Sinister's Avatar
Try Summit or Jegs.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-26-2009, 07:19 PM   #17
El Jay
NAPA, CarQuest
Old 03-26-2009, 07:55 PM   #18
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
O'Reilly's, Advance, AutoZone......Y3
Member Nr. 2770
Old 03-26-2009, 11:25 PM   #19
tim21391
tim21391's Avatar
i checked into the ones at autozone and its a little different but i guess ill make it work i just didnt wanna make new mounts but oh well its life haha thanks guys
