transmission cooler
i have a 90 700r4 transmission and what to hook up a B&M transmission cooler to it how is the best way to hook it up. do i just run the transmission line's to the cooler. or do i still have to use the radiator with the cooler....... was told heat is the number one failure in 700r4 transmisson just what to do my part on keeping it cool...
Re: transmission cooler
My factory cooler uses both the radiator and the auxiliary cooler.
1978 C10 Silverado Big 10 350/350.. play toy 1990 V1500 Suburban 350/700r4..Daily driver 1987 K10 Silverado 383/400.. Wife's rig WRECKED! 1989 V2500 Suburban 350/400.. SOLD! 1974 C10 Custom10 LWB 350/350.. SOLD! 1974 C10 Custom10 SWB 350/400.. SOLD! 1999 Silverado Z71 LS1.. Wife's rig WRECKED! On the hunt for a new project....... I'm a Chevy guy.....I'm just not a "NEW" Chevy guy. |
is a auxiliary cooler a normal cooler or is that a special cooler
Its the factory cooler mounted in front of the radiator.
so your transmission run's threw the cooler and the radiator. dose it matter what one first. is there a certain way the line's are supposed to run. for exsample the top line on the trans where dose it run to and where dose the bottom line run.
I cant answer how the hose routing is but i do know the tranny fluid goes through the tranny cooler and the radiator, so it gets cooled 2 times.
well that's they way i need to hook mine up. so it's geting cooled twice aswell. i will install this as soon as i find out what hose go where. thank's for your help (motomech)
this is how i hooked it up today, i did some googleing last night and came across a post that some one describe how to run the line's.........
. .the bottom tranmission line on the transmission go's to the to on the raidator. . .i disconected the bottom line on the radiator, witch is the top transmission line on the tranny. the transmission cooler came with a nipple fitting i screwed that fitting into the bottom hole on the raidator. witch i then hooked a hose to and ran it to the bottom on the transmission cooler. then i hooked a hose to the top of the cooler and ran it to the bottom line that i disconected from the radiator that is the top tranny line on the transmission. .................i hope this is right i don't no for sure if it matter's or not i was just going to hook the tranny straight to the cooler but was told that it still need's to run threw the raidator. so this is how i hooked mine up today............ |
