Old 03-25-2009, 01:33 AM   #1
Blue85
Oilfield Trash
Blue85's Avatar
Whats This Electrical Contraption?
So, I was wiring in my tach today, hooking up to the dist. cap, I notice that is already a yellow wire coming from the tach, leading to what I think is a relay of some kind mounted on the valve cover. Ive never dealt with one these before, my 74 never had it, nor did my 85, can someone please explain what this is, and how it works?
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 03-25-2009, 01:34 AM   #2
Blue85
Oilfield Trash
Blue85's Avatar
Re: Whats This Electrical Contraption?
Cant get pics to upload, the relay is mounted on the driver side valve cover, the truck has a 350 motor/th400 tranny
87 Chev 3+3 4x4
Old 03-25-2009, 02:05 AM   #3
flamingbig10
6.0 powered square
flamingbig10's Avatar
does it go to any thing
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-25-2009, 11:50 AM   #4
Blue85
Oilfield Trash
Blue85's Avatar
here is the pic>>>
87 Chev 3+3 4x4
Old 03-25-2009, 12:19 PM   #5
Longhorn321
Size Matters
Longhorn321's Avatar
I have no idea but I am interested to know. It might help if you told the year, make and model of truck this is on.
As an aside, why are the V/Cs blue? You're not on here asking about a F@%d are you?
"Reading the owners manual is only for quitters." Jason Harper, Bloomberg News.
...WOOOO HOOOO!!!!
Longhorn321 is offline   Reply With Quote
Old 03-25-2009, 12:48 PM   #6
jchav62
1962 C-10
jchav62's Avatar
I wonder if it's something for the "ESC-Electronic spark control" that these trucks used to come out with? Does the dist. have a vacuum advance?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 03-25-2009, 02:13 PM   #7
Blue85
Oilfield Trash
Blue85's Avatar
The truck is a 1980 GMC K10, 350 motor, I was kinda wondering too why the valve covers were painted like that. But yesterday i was also wondering why the P.O. had the stereo power wire jammed into the horn fuse
87 Chev 3+3 4x4
Old 03-25-2009, 02:22 PM   #8
Prerunner1982
Prerunner1982's Avatar
I was thinking perhaps it is a kill switch? Especially if it is wired to the distributor. The relay would open and close the power to the coil.
Jon
1982 Chevy Silverado 350/th350.... RETIRED
1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231
Oklahoma Roll Call
Prerunner1982 is offline   Reply With Quote
Old 03-25-2009, 02:32 PM   #9
Blue85
Oilfield Trash
Blue85's Avatar
So i took the harness off and this is what i found, still have no clue of its original purpose.
87 Chev 3+3 4x4
Old 03-25-2009, 03:06 PM   #10
westie 666
westie 666's Avatar
Some trucks came out with blue motors, my 77 has a blue motor so I kept it like that, the only thing was I could only get old F@#D blue to repaint it.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 03-25-2009, 03:30 PM   #11
73chevyman
73chevyman's Avatar
well does it still run with out it. if so forget about it lol. hook the tach up and move on. but it probably something to do with a alarm or a kill switch of some sort
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 03-25-2009, 03:47 PM   #12
Blue85
Oilfield Trash
Blue85's Avatar
Oh yeah, she still runs without it, its amazing how much wiring and emissions things you can remove from these trucks and they still run just as good, sometimes better.
87 Chev 3+3 4x4
Old 03-25-2009, 05:05 PM   #13
JohnC
JohnC's Avatar
Yeah I know. Mine has the majority of the vacuum lines capped off. Still runs fine so on we go!
JohnC is offline   Reply With Quote
Old 03-25-2009, 05:16 PM   #14
enaberif
I only have 2 vacuum lines: Transmission and Distributor
enaberif is offline   Reply With Quote
Old 03-25-2009, 05:55 PM   #15
jchav62
1962 C-10
jchav62's Avatar
I have four...those two, the brake booster and the PCV...
Joseph Chavez
Old 03-25-2009, 06:53 PM   #16
88 Dippy
88 Dippy's Avatar
i only have the dizzy vacuum and break booster
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 03-25-2009, 11:15 PM   #17
red caddy
I have that same setup on my '86 1 ton, No clue what it does or what connects to the 3 rd plug. I looked in an '86 Motors manual, went cross eyed reading the schematic's before I found any thing that resembled that harness.
Did the mid 80's trucks have a clutch interlock (like some Ford trucks) that would only let the engine crank if the clutch pedal was down?
This one has me scratchin' my little bald head... RED
red caddy is offline   Reply With Quote
Old 03-26-2009, 01:09 AM   #18
DirtyLarry
Windy Corner of a Dirty Street
DirtyLarry's Avatar
That is weird. I have never seen an OEM relay bolted to the valve cover, of all places, on any GM vehicle. It just doesn't look like something the General would do. A relay right on a heat source doesn't seem like a good idea. I am guess this is somekind of relay contraption for some aftermarket dodad. Maybe some long gone JC Whitney cruise control contraption or something.
Blue engines came to be around 1977 or 78. Then they became black after 1981.
DirtyLarry is offline   Reply With Quote
Old 03-26-2009, 01:18 AM   #19
Blue85
Oilfield Trash
Blue85's Avatar
looks pretty factory, gm logos on plugs and relay, mounting bracket on valve cover has factory style spot welds etc. Cruise was my first thought too, but the truck has factory cruise that works.
87 Chev 3+3 4x4
Old 03-26-2009, 07:22 AM   #20
ElGracho
Gentleman Jim Driver
ElGracho's Avatar
Is there a key lock cylinder in the fender?
Joe
'75 GMC Gentleman Jim
'84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter)
'85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans
also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed
ElGracho is offline   Reply With Quote
Old 03-26-2009, 04:35 PM   #21
Rob73-87
Rob73-87's Avatar
That has been done by the previous owner !
I have the same relay in my cabin under the dash - and THAT`S ORIGINAL.
My truck has been a diesel, so I think it has something to do with the pre-glowing of the diesel engine !!?
I`m not quite sure about that - if someone knows better please correct me.
Rob
Rob73-87 is offline   Reply With Quote
Old 03-26-2009, 09:05 PM   #22
lurch115
lurch115's Avatar
Rob
if the truck was converted from a diesel to a gas that relay and such would have stayed with the diesel since the diesels don't use a distributor, and they also have different valve covers.... that and the glow plug controller is larger than that relay...
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-26-2009, 09:20 PM   #23
sierra4x4
sierra4x4's Avatar
I know that is factory becouse I have two truck with the exact same thing. One is a 84 3/4 ton 2wd with a 350/TH400 all original powertrain. The other is a 86 3/4 ton 4wd with a 350/TH400 and it also has it. Ihave no clue what it does though.
sierra4x4 is offline   Reply With Quote
Old 03-27-2009, 12:25 AM   #24
Blue85
Oilfield Trash
Blue85's Avatar
Somewhere i'm sure somebody knows what this is lol. Where in sask are you from sierra4x4?
87 Chev 3+3 4x4
Old 03-27-2009, 12:41 AM   #25
f.monroe
f.monroe's Avatar
I do not really deal with the 81 and up trucks but from the sound of things , its may be a kickdown relay for the th400 . I know that they are electrick kickdown and all of the trucks mentioned above that have one also have th400's . I have never seen one like that or if I have , I didnt pay attention to it .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
