Old 03-25-2009, 03:39 AM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
idiot lights to gauges
I have a nice bezel with gauges. I want to put it in my truck. Is there any way I can run it with out changing my whole harness. If not and I plug it in will my gas guage at least work
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 03-25-2009, 05:59 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: idiot lights to gauges
your fuel guage will burn up if you just go out and plug it in.
GMC Paul has a chart on his site, shows what wires to trim and cross to make it work.
Old 03-25-2009, 09:26 AM   #3
69lemans
Here is the link
http://www.gmcpauls.com/Tech%20Tips1.htm
69lemans is offline   Reply With Quote
Old 03-25-2009, 10:34 AM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
Does someone have a picture of the idiot lights cluster. i have no idea what they look like......
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-25-2009, 10:46 AM   #5
mrh33916
Project '67 454
mrh33916's Avatar
Great info, I plan on doing that swap as well and didn't know it would burn up the fuel gauge if not properly installed, Thanks
mrh33916 is offline   Reply With Quote
Old 03-25-2009, 02:42 PM   #6
69lemans
Old 03-25-2009, 03:51 PM   #7
jbristo67
jbristo67's Avatar
I am excited it can be done. I wanted a gauge dash pretty bad.
2011 Nissan Armada
Old 03-25-2009, 05:38 PM   #8
Longhorn Man
As i've said in teh past... if you just slap it in, you'll get funny working inst lights, the turn signals will control a high beam and an inst light if I remember right, and the fuel guage will spin around and then go out in a puff of smoke.
Ask my old friend, he watched mine do this and he was literally laying in the dirt holdin his belly he was laughing so hard.
I on the other hand, wanted to cry.
Alcohol may have been involved.
Old 03-25-2009, 06:16 PM   #9
my67chevytruck
Under Construction
Thanks for the PIC.... Andy
Heath
FAQ how to's
1956 Chevy Apache
56 chevy truck :
67 truck build:
69 k10:
Old 03-25-2009, 10:37 PM   #10
jbristo67
jbristo67's Avatar
You always have the best stories
2011 Nissan Armada
Old 03-25-2009, 11:57 PM   #11
Longhorn Man
sad part is... it is 100% real.
Old 03-26-2009, 10:26 AM   #12
67chevemall
67chevemall's Avatar
Very small flat head screw driver and just take one wire plug out at a time and switch them all around. ( As per GMC pauls wire chart)
You will need a new oil sensor and steel line for the oil gauge to work.
I think the temp sensor is different too. (no chance to try mine out yet)
A hose for the vacum line connected to the bottom of the carb
Run a wire to the Dizzy for the tach. And a + - wire to power the tach.
And you have to run wires for the Amp gauge to the Alt and Batt.
Good idea to check all the bulbs too before you put it in.
Be carefull around the plug when putting in and out of the truck.
Good weekend project. Get a case of beer too.
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 03-26-2009, 02:17 PM   #13
jbristo67
jbristo67's Avatar
Of course
2011 Nissan Armada
Old 03-26-2009, 07:46 PM   #14
oldgold70c10
Who's got steelies?
oldgold70c10's Avatar
It is a pretty easy mod. This is how I did my burb: I ran 2 new wires out to the bat and alt. for the ammeter, and just used a small screwdriver to swap all the others around. You'll want to cut and connect together the two green temp wires where they go to the ignition switch, otherwise your temp gauge will peg at hot every time you start the truck.
1969 C10 LWB W/ 250 I6 & 3spd
1970 C10 with '67 small window cab, 68 front end, blue; 305/TH350, 3.08 limited slip rear end, manual brakes, power steering; & 4-wheel drums-My daily driver.
1975 Chevelle Malibu Classic Coupe 350/th350 mint green
1970 C20 Suburban 350/700R4 4.10 gearing green & white
1978 Big 10 Silverado 350/th350, working ac, 2 tone blue-My summer daily driver
1983 GMC 1500 Sierra 305/SM465 2.73 rear end
How to add a trip odometer to your 67-72 stock speedometer
How to rebuild your Q-Jet
My Truck Page
My Youtube Channel
oldgold70c10 is offline   Reply With Quote
