Old 03-25-2009, 04:04 AM   #1
enaberif
Manifold to exhaust pipe
Do our trucks use any gaskets where the manifold connects to the exhaust pipe?
I checked LMC but don't see anything.
enaberif is offline   Reply With Quote
Old 03-25-2009, 04:54 AM   #2
Prong
Re: Manifold to exhaust pipe
They use an exhaust donut. You should be able to find 'em at your local parts store.
Prong is offline   Reply With Quote
Old 03-25-2009, 04:05 PM   #3
enaberif
Ok so I took at a look at the manifold has a rounded edge where it goes into the pipe and the pipe is flared where it sits against this round piece.
Do you still need a gasket.
Old 03-25-2009, 04:52 PM   #4
JohnC
JohnC's Avatar
Yeah just like Prong said. It's a donut style gasket. It fits right where the circles are that you are looking at. It's not flat like other gaskets.
JohnC is offline   Reply With Quote
Old 03-25-2009, 04:55 PM   #5
enaberif
So I need a gasket that fits over the rounded part on this manifold?
Old 03-25-2009, 04:58 PM   #6
JohnC
JohnC's Avatar
Yeah where the manifold and exhaust pipe meet. Your local parts store will have them. Tell them what you need, and they'll fix you up.
Old 03-25-2009, 05:03 PM   #7
enaberif
Yah I did and the donut fits fine into the pipe leading to the mufflers but not the manifold hrm.
Old 03-25-2009, 05:08 PM   #8
JohnC
JohnC's Avatar
Hmmm. Mine have always fit pretty good. Maybe someone else will pop in and help out. Other than that I would say put it on the exhaust pipe where it fits, and then try and tighten it up. Sorry I can't help any more than that.
Old 03-25-2009, 05:15 PM   #9
enaberif
Yah I figured it wouldn't be this difficult.. but then again.. I've had to fight with a few things.
I'll wait for other opinions.
thanks.
Old 03-25-2009, 08:31 PM   #10
westie 666
westie 666's Avatar
Is your manifold a smaller size than your exhaust?
IE: 2 inch manifold and 3 inch exhaust pipe.
77 Cheyenne no longer in bits
westie 666 is offline   Reply With Quote
Old 03-25-2009, 08:36 PM   #11
enaberif
Other way around. The manifold is larger than the pipe.
Exhaust pipe is FLARED to fit over that rounded part. Which to me makes the seal but what happens when the truck is warm? And the pipe heats up? Would that not cause a air leak?
Old 03-25-2009, 08:45 PM   #12
westie 666
westie 666's Avatar
OK now I'm confused, the donut type gasket fits inside the manifold and the exhaust pipe, you state the you have it over the manifold???
Unless your manifold is not the same as most of our trucks.
I think a pic or two may help.
Old 03-25-2009, 11:04 PM   #13
enaberif
Best I can do without actually using a camera:
Manifold has a flange that is curved. This flange fits into the exhaust pipe which is flared. They are joined together by a 3 bolt bracket.
Old 03-25-2009, 11:23 PM   #14
westie 666
westie 666's Avatar
With what you are trying to do, the external diameter of the manifold should match the internal diameter of the exhaust pipe so it fits inside and creates a seal. It's been so long since I have seen this type of set up I may have it wrong, your best bet is to take the truck to an exhaust shop, it may be a simple fix like a bigger or smaller donut.
