Old 03-25-2009, 10:44 AM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
transmission stop leak
i have a slight leak of transmission fluid from my transfer case and i think i might just put some transmission stop leak in it...what do you guys think good or bad idea
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 03-25-2009, 02:27 PM   #2
Fer79
Fer79's Avatar
Re: transmission stop leak
I had the same problem, change the gasket and resolve problem, my transmission is a th700r4
Fer79 is offline   Reply With Quote
Old 03-25-2009, 03:50 PM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
If that kind of stuff really worked Aamco would be out of business.. That stuff usually does more harm than good, and frankly i would only use that if i were stuck in some backwood county and heard the drum beats of "Deliverance" approaching as i popped the hood of the truck.
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is online now   Reply With Quote
Old 03-25-2009, 04:28 PM   #4
78gmc
if you use anything use lucas what t case do you have. if it is a np208 use lucas trans fluid. if it uses oil use lucas oil additive.just read the bottle and get the one for that kind of lube.
78gmc is offline   Reply With Quote
Old 03-25-2009, 04:47 PM   #5
JohnC
JohnC's Avatar
Originally Posted by old Rusty C10 View Post
If that kind of stuff really worked Aamco would be out of business.. That stuff usually does more harm than good....
I agree. If you are planning a rebuild in the near future, and are just wanting a quick fix then go for it. Other than that I would go ahead and change the gaskets and new fluid.
JohnC is offline   Reply With Quote
Old 03-25-2009, 05:44 PM   #6
pokethesmot
its a np 208
Old 03-26-2009, 03:42 PM   #7
78 Chevyrado
x2 on lucas. I'd put it in there even after you fix the leak. But it's thicker and won't go out the leaks as easily. My th400 had a tad of a leaky converter seal and was slipping and I was planning on a tranny rebuild. I put the lucas in and now it doesn't leak, and shifts right with no slipping, so the tranny can be put off for a WHILE. I put the oil stuff in my old 400 before I rebuilt it and it cut my bad main seal leak in half. it makes a good band-aid, but it is just a band-aid if that's what you're using it for.
78 Chevyrado is offline   Reply With Quote
Old 03-29-2009, 03:43 AM   #8
mexgrhd68
mexgrhd68's Avatar
X3 on the Lucas, my 79 was leaking all over the place before i pulled it out, its in the rebuild stage now
68 c-10 1/2 ton swb fleetside, 79 GMC Sierra Grande 1/2 ton swb fleetside, 99 Dodge Durango 4x4(wifes ride),53 and 55 chevy trucks(dads trucks )
54 caddy 62 series 4 door(younger sons ride, aka 54caddy )
70 caddy 2 door, 89 chevy silverado stepside(older sons rides )
mexgrhd68 is offline   Reply With Quote
Old 03-29-2009, 07:07 PM   #9
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Bob, you never cease to crack me up. A lot of guys here have probably never seen the movie Deliverance.
Back to the question at hand, take the time to fix the leak. Stop leak products have a tendency to plug other orifaces that need not be plugged.
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 03-29-2009, 07:25 PM   #10
S10Fan
Old Heap Driver
Kind of like Deliverance.
_____________________________
Bryan
'99 Silverado 1500, 4.3, 5-speed, reg cab, short bed
'50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser.
'40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver.
S10Fan is offline   Reply With Quote
Old 03-29-2009, 07:25 PM   #11
blackdiesel
blackdiesel's Avatar
It was a BANJO not a drum. LOL
'57 Chevy Pickup
'56 GMC LCF Cummins
'38 Chrysler Royal
'57 2wd change
http://67-72chevytrucks.com/vboard/s...light=speedway
blackdiesel is offline   Reply With Quote
Old 03-29-2009, 07:33 PM   #12
babyJay
babyJay's Avatar
exactly....and the trans will squeal like a pig....
Jason
89 R3500 CC SRW
Old 03-29-2009, 07:35 PM   #13
S10Fan
Old Heap Driver
Nevermind, this is a family site.
LOL!
Bryan
