Window Regulator Help
When I bought my truck the person before me had already replaced the drivers window regulator. The window would roll down fine but coming back up was another story. It was hard to roll back up. The regulator messed up and I replaced it again. I greased the track REALLY good upon installing the new regulator. Now it is back to being easy to roll down but difficult to roll up. Is there something that I am missing when installing the new regulator? Seemed like a really easy unscrew/re-screw operation, not much to it. I just don't want to be replacing the regualtor every couple of months. Any help would be great, thank you
Re: Window Regulator Help
Is the felt, all the glass run set, and channels in good shape? mine does the same thing, if all that stuff isn't in good shape it will cause the window to tilt side to side and hang up. at least mine did
All the tracks look good, the person before me put all new felt/ track strips in when he did the reg, they look in good shape wiht no wear makes
Are you using repro regulators? When I installed my NOS Gm units, I used a combonation of white lithium grease and petroleum jelly in the tracks and absolutely dosed the rollers, tracks and springs in the stuff. They move very smoothly and the combo seems to work very well especially with new rubbers and vent felts
67 blue step side- bb 68 gold and white swb cst anniversary 68 custom swb hot rod Ls swap 69 swb cst 6 cylinder/ overdrive 69 black/black cst bb swb 70 orange and white cst Canada built truck swb bb 71 black and white super swb bb 71 red and white super swb 72 green and white super swb 4x4 62 nova wagon 400 series Ls swapped 68 Camaro 327/4 speed- 1 owner, original paint 66 Volkswagen bettle 69 auto stick Volkswagen Beetle |
Always Fixing Things
Is the spring in good shape and under tension? Maybe it slipped off the tab?
Just an Average Joe ![]() ‘68 GMC 307 3spd – My dad's original truck 310,000 miles Last edited by SacramentoJoe; 03-25-2009 at 01:59 PM. |
The regulator that the person before me used and the one I put in were both from LMC. I did get a little carried away with the grease in the tracks. I am really at a lose with it. The passenger door was repalced the same time the drivers was the frist time and it is easy down and up until it gets about 3 inches to the top then it gets a little harder but not near as bad as the drivers side from start to finish. The weather is good right now so I am riding my bike to and from work, I will be taking it back apart this weekend to see what I can find out.
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I realy think that you are having weatherstrip problems. I think that the division bar felt is pinching the window sill if you replace the divison bar felt, you should solve your problem. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
I have the same issue. The window goes down smooth and easy, but its bringing it back up when it becomes difficult. I lift the window by hand and it allows the crank to turn freely. Got the Classic Parts Window Regulator Repair Kit on order. 15 bucks, it should work for me. i hope.
I am a Referee of life.
I had the same problem.Now I spray the felt with silicone lube ocassionally.Usually about as often as I lube door hinges latches and such.I have no more problems.It first started when i replaced division bar felts.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
Moderator
![]() Join Date: May 2007
The repro regulators are poor quality. I have them on my SWB, and they started having problems after about a year. I drive the truck daily, and roll the windows up and down several times a day.
My other 72 LWB has the original regulators in it. I have cleaned and lubed them very well, and they work just like they did 40 yrs ago. Like most other parts, OEM are without a doubt the best. |
![]() Join Date: Oct 2007
Make sure the screws are tight that hold the wing window against the doore frame.. If they are loose the track in front of the window glass could get tight when rolling up the window..
I bought one of those repair kits from CPs,my questions are does it come with directions and what position do I set the regulator(the part with saw teeth)when I rivet the crank assembly on???Anybody!!
