03-25-2009, 11:54 AM | #1 |
HEI question
I want to install HEI unit on my 72-350/350, bought one from Skip White. As it is now, I can barely get my fingers between firewall and original distributor cap, this new cap is bigger, its a 4x4 so I think engine sits back a ways, has anyone run ito this problem, if so how did you solve
03-25-2009, 12:04 PM | #2 |
Resident Curmudgeon
Re: HEI question
How are your cab mounts? I've installed GM HEI's in 2 different 3/4 ton 4x4 with small block engines. It's tight but doable. One needed slight massaging with a BFH.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
03-25-2009, 12:56 PM | #3 |
Re: HEI question
Gotta agree with CPNE, I have the lock ring on my wires so it is even closer. About 1/2"
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
03-25-2009, 04:34 PM | #4 |
Active Member
Re: HEI question
One thing to be aware of, if you ever get hit from behind or back into a solid object, like a concrete filled pipe, the motor mounts may have enough give to crack the cap. Happened to me.
03-25-2009, 07:32 PM | #5 |
Re: HEI question
I thought Skip White also has a HEI cap that is slightly smaller diameter that fits too?
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
03-25-2009, 10:01 PM | #6 |
Re: HEI question
03-25-2009, 10:01 PM | #7 |
Re: HEI question
CHEVY SBC BBC READY TO RUN HEI DISTRIBUTOR RED #8926-R
FULLY ELECTRONIC DISTRIBUTOR SMALL BASE DESIGN, Item number: 260371797991
03-25-2009, 10:05 PM | #8 |
Re: HEI question
You see, I already bought the distr., just failed to mention its for a 4x4, I am going out right now to compare these numbers, Thanks Sammy
03-25-2009, 10:24 PM | #9 | |
Re: HEI question
#6500 |
03-27-2009, 12:40 PM | #10 |
Re: HEI question
jarros, take a look
03-27-2009, 01:04 PM | #11 |
Re: HEI question
Here ya go...my locking ring is about 1/4" away from firewall (diameter of ring is 5 1/2"). I have poly mounts w/ a new DIY4X crossmember, but I think I will still have to dent the firewall a bit. There is enough matrl. on the ring to cut about a 1/2" off the ring and that is the biggest part of the HEI
LMK if you need more pics
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 03-27-2009 at 01:06 PM. |
03-27-2009, 01:12 PM | #12 |
Re: HEI question
That looks awful tight! What is the unit they sell to install and use your stock distibutor cap.
03-27-2009, 01:15 PM | #13 |
Re: HEI question
Don't understand the Question
03-27-2009, 01:22 PM | #14 |
Re: HEI question
I had it done on my 57, they took points out and installed HEI in original dist. I dont know what they did or how as I am not mechanically inclined, all I know is there are no points in my distr. Maybe someone will chime in, Thanks Jim
03-27-2009, 01:34 PM | #15 |
Re: HEI question
Well, what ever it is, it would give you more clearance than the HEI. It's tight and I don't see anyway around it, other than banging in the cowl. Yours is all painted and shiny so it doesn't look like an option for you
03-27-2009, 01:42 PM | #16 |
Gone to greener pastures
Re: HEI question
IIRC, I believe Pertronix(sp?) makes a kit to convert a points distributor to electronic.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
03-27-2009, 02:20 PM | #17 |
Re: HEI question
03-29-2009, 03:44 PM | #18 |
low n' slo
Re: HEI question
wow, there is no room at all behind that thing. i just got mine in today, same exact one from white off ebay, dropped it in and i have tons of room til i hit the firewall (67 suburban). i dont see any other way to put it in unless you bang out the firewall. just use a rubber hammer, the dizzy is gonna block that area anyways so it wont be visable if you scratch it up some.
03-29-2009, 11:13 PM | #19 |
Hybrid67
Re: HEI question
I have a similar set up in my 67 and its TIGHT!!! But it's there and it works. You won't have much room left at all and should be able to get it in.
Steve |
03-30-2009, 12:09 AM | #20 |
Re: HEI question
You can always buy an HEI unit with an externally mounted coil,the dizzy cap is no bigger than the caps for points,no need to take a hammer to the fire wall.
MSD has many different dizzys with small and low profile caps. |
