Sierra Grande Club
Brake fluid recommendations.
I have some Valvoline synthetic Dot 3-4.
Just wanted to ping you guys on what you found to be the best for our trucks. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
![]() Join Date: Jan 2000
Re: Brake fluid recommendations.
I use ATE.
It is standard on Porsche. I want to believe it makes the truck stop faster (hahaha). The ATE fluid does have a higher boiling point and additional moisture inhibitors than other standard brake fluid (even more inhibitors than Castrol LMA). If you are flushing old fluid out, ATE has both a regular gold/brown color and a blue color brake fluid. Using alternate color fluid makes it easier to tell when you have finished flushing out the old brake fluid. I got mine locally but here is a url from Tirerack for ATE http://www.tirerack.com/brakes/ate/a...e200_amber.jsp |
its all about the +6 inches
fresh DOT3 is all you need. The stuff is designed to absorb water for a very good reason, and with the extreem temerature differences you have there, it's somewhat important.
I'M TRUCK CRAZY!
yep... Dot 3 is fine. The higher the Dot the more heat it can take. Bikes use Dot 4 or higher.
EDIT: any bike i have seen that is... Last edited by LOW DOUGH; 03-25-2009 at 05:40 PM. |
Sierra Grande Club
Is the 3-4 synthetic any good then? I guess it's for both?
s/t
![]() Join Date: Sep 2005
yup ti will be fine
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
