Old 03-25-2009, 03:58 PM   #1
1972CST
1972CST's Avatar
Patch Panel ?
I am having a little trouble finding out how far this pillar patch comes down in comparison to the brace in the pic. Do these holes line up exactly? I know some of you guys have done this allready. Any help is much appreciated.
1972CST is offline   Reply With Quote
Old 03-25-2009, 10:52 PM   #2
packers05
Re: Patch Panel ?
I am just finishing mine, I recommend you buy the part that welds to the pillar patch contact wes at heartbeat hes only one i know of who has it , in regards to holes lining up in repair panels to origanal I have no luck doing it that way so far but its not completed either so we shall see
packers05 is offline   Reply With Quote
Old 03-26-2009, 03:12 PM   #3
1972CST
1972CST's Avatar
Re: Patch Panel ?
I still have a few more panels to buy but I was trying to get started w/ what I have. What makes it so hard is there is nothing left in this area to give me a reference point except the small brace. Maybe someone could take a measurement from a reference point down to the bottom of the pillar patch?
Old 03-27-2009, 06:54 AM   #4
vtblazer
vtblazer's Avatar
Re: Patch Panel ?
Picture help any?
[IMG][/IMG]
How can I measure this best to help ya out?
Sorry:
Have the pic for you but the board isn't allowing anything right now, I'll check back and post it later.
vtblazer is offline   Reply With Quote
Old 03-28-2009, 10:35 AM   #5
1972CST
1972CST's Avatar
Re: Patch Panel ?
Originally Posted by vtblazer View Post
Picture help any?
Sorry:
VT- I was thinking of using the top bolt for the rocker box support as a reference point. I will try to post a pic. Thanks for your help.
Old 03-28-2009, 11:22 AM   #6
badpeanut
Not a bad nut after all..
badpeanut's Avatar
Re: Patch Panel ?
Subscribed!
'05 Chevy 2500HD 4x4
'72 GMC LWB 4x2 driver
'72 Chevy LWB 4x4 plow truck
'71 Blazer 4x4 driver
'70 GMC LWB trailer
badpeanut is offline   Reply With Quote
Old 03-28-2009, 02:29 PM   #7
70 Suburban
Rods
Re: Patch Panel ?
your local nut and bolt should have the square nuts they are cheeep. as for the referance I went to home depot and bought a tool that wood workers use to find molding shapes. just use the outside bed panel for referance transfer that to paper.
70 Suburban is offline   Reply With Quote
Old 03-28-2009, 05:08 PM   #8
1972CST
1972CST's Avatar
Re: Patch Panel ?
I think there may be some confusion. I am installing a new lower b-pillar extention. This area was completly rusted away so I was looking for a reference point to get me close to where the original was. I thought someone could measure from the top bolt down to the bottom of the pillar extention. The only problem is you would almost have to be in the middle of this repair to provide this info.If the floor is already in place,this measurement could be taken from the bolt to the floor and then from the floor to the bottom of the pillar extention. Sorry for the confusion and thanks again for any help!
Old 03-28-2009, 09:27 PM   #9
jaros44sr
jaros44sr's Avatar
Re: Patch Panel ?
I would use the body crease on the lower fender as a reference, this will set the elevation
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
