Old 03-25-2009, 09:13 PM   #1
Longstep70
Junior Member
Help me with these rallies
I have these rallies on my 68. i guess they are 73 + rallies with the 10 hole pattern; 6 lug. I did my disc brake conversion and got the usual side effect of the front wheels moving out and now I'm worried about rubbing. I've looked for truck rallies to see if i can get these in different backspacing to tuck the front wheels a bit but i haven't seen this exact style - i found the 5 hole ralley and the regular truck ralley with more than 10 holes but not this exact one. what are they from and can I get them in multiple backspacing?
-Andy
Longstep70 is offline   Reply With Quote
Old 03-26-2009, 01:00 AM   #2
PHAT TONY
PHAT TONY's Avatar
Re: Help me with these rallies
I've been all over the 'net and haven't found any options;I like these wheels as well(converting a 5 lug to 6 so's I can use them).
PHAT TONY is offline   Reply With Quote
Old 03-26-2009, 07:01 AM   #3
Hottrucks
Redefining LowBudget
Hottrucks's Avatar
you could always have you wheel centers cut out and have the back spacing changed..it's not that expencive??
1970 C10 CST fleetside 472 ....big dreams little cash...
SunShine Syndicate..
Mikes Sandwich Fair Run OCT 8th 2011
Hottrucks is offline   Reply With Quote
Old 03-26-2009, 07:06 AM   #4
my67chevytruck
Under Construction
my67chevytruck's Avatar
lets see more of that '68. I cant recall what year i have seen those rims on...
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
Old 03-26-2009, 07:17 AM   #5
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Stockton wheel has what you need.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 03-26-2009, 07:26 AM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
When I did the drum-to-disc conversion on my '69, the 8-inch wide wheels on the front did stick out and would rub on the wheel opening if it bottomed out or in a turn. So, I swapped them for some 7-inch wide wheels I had on my other '69. Solved that problem.
Those wheels didn't come out until about '76. I don't think there were any but 8-inch wide wheels. I am also going to guess that they have a 4-inch backspace.
I wanted some new wheels so I ordered Wheel Vintiques from Summit Racing. Fronts are 15x8 with a 4-inch backspace. Rears are 15x10 with a 5-inch backspace. 245-60's up front and 275-60's out back round out the rolling stock.
Member Nr. 2770
Old 03-26-2009, 08:56 AM   #7
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Mine stick out a bit but they don't rub.As stated Wheel Vintiques(Ihtink) as well as Stockton has them and IIRC they do whatever width backspacing you need.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-26-2009, 12:38 PM   #8
Longstep70
Junior Member
I'm kind of stuck between a rock and hard place here. I like the wheels and wanted to keep them so when i did my disc brake conversion I stuck with the 6 lug so I wouldn't need to replace the wheels. I guess i am a little surprised by how much the wheel moved out with the new spindles.
I have looked at Stockton and Wheel vintiques and if i went that route i'd be paying as much if not more than a pair of the new modular CPP spindles that would tuck the wheels in more. I guess these are the 4x4 wheels from the 70's rather than the stock truck rallies? Are regular truck rallies around in varying widths and backspacing or would I again be looking at custom made wheels?
-Andy
Old 03-27-2009, 07:34 AM   #9
68Stepbed
68Stepbed's Avatar
The 6-lug 4x4 rallies like you have are only available in 8" wide widths unless special ordered from a place like Stockton Wheel. The 5-lug 2wd rallies were originally available in 8", 7", and 6.5" widths.
You could go with a set of Vette style rallies available in 6 lug and correct backspacing. They would still be cheaper than the custom rallies from Stockton.
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 03-27-2009, 07:56 AM   #10
69c10step
69c10step's Avatar
Just as a point of reference - I sent my rallies to Stockton Wheel a year or so ago - had them widened to 12" with a custom back space - cost = $135 each plus optional powder coating = $55 each. Very happy with the work.
'69 short step with dreams of being a hot rod
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
69c10step is offline   Reply With Quote
Old 03-27-2009, 08:11 AM   #11
70STOVEBOLT
70STOVEBOLT's Avatar
I also have these wheels on my 70, and I am going to convert to disc brakes using my stock spindles. Will I have this same problem with the wheels being moved further out?
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
