03-25-2009, 11:57 PM | #1 |
POR 15 VS. Powder Coat
I have a 68 Short Stepside and I am planning a frame off and I was wondering if I should go spend the money for the powder coat or paint the frame with POR 15 and a top coat of chassis black
03-26-2009, 12:06 AM | #2 |
Moderator
Re: POR 15 VS. Powder Coat
I vote POR 15 all the way. If you got the $$, powder coat.
03-26-2009, 06:51 AM | #3 | |
Sierra Grande Club
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-26-2009, 08:31 AM | #4 |
Just got my frame back from getting powdercoated, there is no comparison to por15. That stuff sucks in comparison.
POWDERCOAT ALL THE WAY!!!!!! I will post pictures this weekend when I roll it ouside
1972 K5 - LS3/408 (595Hp) -6L80e-One Tons with 4.56, 20'' Beadlocks with 37'' rubber, full TMI interior, JL Audio ..... 1971 CREWMAX Build.....at body shop for couple more years |
03-26-2009, 08:36 AM | #5 |
POR-15 is a PITA to use. Too many steps. I would vote for Powercoat if you have the $$.
03-26-2009, 10:07 AM | #6 |
Project '67 454
It depends on what your willing to spend and what results your looking for. Por-15 would be a less expensive way of making the frame look descent if you want to do it yourself and save money. if you're going to send it out to be done than powder coat it,
03-26-2009, 11:46 AM | #7 |
Moderator
If it is applied properly, por 15 is extremely durable. I have used it on Jeep frames for years, that see a lot of offroad use, and it does not chip or flake except under extreme circumstances, which will also happen to powdercoating
03-26-2009, 04:39 PM | #8 |
What are you guys paying to have a frame power coated?
Doug Looking for a 67-72 short bed driver..... |
03-26-2009, 04:48 PM | #9 |
Mine was $525, that was with them having to order a non-stock color, sandblasting and putting a clear coat on it. PLUS I had them do my leaf springs, crossmembers, traction bars and some misc brackets. I thought it was a steal. It all turned out beautiful, no corners cut!! I would recommed them to anyone. Matter of fact it is worth the drive for almost anyone within 4 or 5 hours.
03-26-2009, 06:13 PM | #10 |
sharp as a marble
When I am asked this here, I always think about what my time is worth. My employees will tell you that it is worth nothing. I agree most of the time. There is absolutly no comparison to the two. I will be taking my 72 Blazer off the frame later this year, and me and the local powdercoater will be BUDS before it is over. Lasts forever, and OOOh la la it looks so good. I powdercoated my last frame off, and the new owner never wipes it off, and it still looks good
03-26-2009, 06:21 PM | #11 |
Powdercoat is great until it gets scratched, starts to lift, and rusts from underneath the powder coat. POR-15 won't do that.
When I grow up, I want to be the man my wife married. I used to be schitzophrenic, but we're O.K. now |
03-26-2009, 07:12 PM | #12 |
dipped and powdercoat 750
03-26-2009, 09:48 PM | #13 |
its all about the +6 inches
powder is great for a truck that'll live in the garage and not be driven every day.
POR is AWESOME for something that will get driven. For anyone who thinks powder coating is all durable and stuff... go to a truck stop and look at the rear frame rails on every rig out there. Every single one of them used to be powder coated when it was new. That was new virgin steel... not 40 year old cleaned up steel. I por's the rear of the frame on the longhorn back in 05 and it has been my daily driver since then. It has sat for a total of 5 or 6 months when I was driving the burb. This longhorn goes through rock salt, salt brine, goes all winder without getting washed... and when I clean it off... it looks great. No chips, no rust, no peeling, no bubling rust underneath... POR when done properly (and I never even used the marine clean or anything) is awesome. |
03-26-2009, 10:14 PM | #14 |
I used POR15 on mine. I also sand blasted it myself. The POR 15 was easy to do (I sprayed it.....read warnings). However I really wish I would have payed a little money to get the frame sand blasted. It took me hours and hours to sandblast it myself.
03-26-2009, 10:37 PM | #15 |
6600duramax where did you go i have been using a guy in herculaneum missouri for powder coat he is very reasonable and does great work
*SOLD* 1968 Chevy SWB Fleet 350/350 combo Tach/tilt/buddy buckets Bagged/18" Wheels Black on Black Project "Pandemic" the Farm Rat 1927 Chevy Capitol Truck Rat rod '30 Model A Frame Dual Carb 5.3 LS http://www.67-72chevytrucks.com/vboa...d.php?t=804162 2007 GMC 4 DOOR 2WD BUILT 5.3 STAGE 3 CAM 93 TUNE LIFTED 22X12 WHEELS 33" TIRES 2023 Jeep RENEGADE Wifes ride |
03-26-2009, 10:43 PM | #16 |
Formerly- 1972SuperCheyenne
I have used PM Industries multiple times. Works just as good as POR-15 but cheaper. Doesn't chip, lift, etc. Great product. Powder coat is awesome for a trailer queen but as soon as it gets scratched it's all over.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
03-27-2009, 12:03 AM | #17 |
I just ordered some of this tonight after reading your post. I really want to see how this stuff works! I need to spray my 71 Fleetside SWB Frame.
All Toys: 1971 C10 Fleetside - I needed it! 1970 C10 Stepside - Midlife Crisis 1969 C20 3/4 Longbed - Beast! 1966 Mustang Fastback - Daily Fun 1965 Mustang Fastback - Money pit! Last edited by 70C10Step; 03-27-2009 at 12:03 AM. |
03-27-2009, 12:26 AM | #18 |
Im a fan of Powder Coating, looks really sharp. I got my frame, cross member and all suspension done for $500. It included sand blasting and they cover up the threads on the stuff that need it covering. One thing the guy that did mine recomended that if you scratch something just hit it with regular spray can paint, I got my frame done in semi gloss black, so a regular craylon spray can will do.
JMO
Leo70 1970 Chevy Shortbed 1956 Chevy 210 Post 1963 Chevy Impala SS Rag..SOLD! |
03-27-2009, 07:49 AM | #19 |
If you brush it on it is very high gloss and self leveling. Doesn't show any brush marks. If you spray it on it is not quite as high gloss but still very nice and has a nice shine to it still.
03-27-2009, 08:00 AM | #20 |
Hey Firedog I live in Festu s also, we will have to meet up sometime. The guy in Herky really wouldn't work well with me so I had Pro-PowderCoating in Jefferson City do it for me. Again it was a 3 hour drive each way but it was more than worth it. Pro-Powdercoat was awsome to work with, there phone number is 573-782-3842 if any one is interested.
