Hi, Have 73 gmc 350 w/hei dist. When i changed the harmonic balancer from orig
to liquid the timing mark changed and could not time a 8 deg or time at all. AT present the motor won't start. Have remote starter setup. Does the ign key have to be on or off. How to get to TDC. Does the #1 plug have to taken out. How do i get per chevy truck manual get to 530 on face clock. Please help ![]() |
Re: installing hei dist/finding tdc
ALso have standard tran.
A quick way to find TDC, with your intake on I assume, is to pull your #1 plug, stick your finger in there, and bump the engine over either with another person or with a remote starter until your finger "pops". At that point, your piston should be at TDC, you can feel for it with a small screwdriver to check. Then check your rotor and see which direction it's pointing, mark it, that should be your #1.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip '68 Plymouth Road Runner 383, 727, 3.23 Sure Grip '89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip '77 Dodge Monaco ex cop car 440, 727, 2.71 '79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip '12 Dodge Challenger SRT8 392, M6, 3.92 '85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73 Last edited by 85Bowtie; 03-26-2009 at 03:26 PM. |
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside ![]() If it ain't a Chevy it's foreign ![]() http://hotridesmag.com/ |
