Old 03-26-2009, 03:11 PM   #1
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
Weiand or Edelbrock intake for BB?
In case anyones wondering i have a few threads going as I am researching parts (thanks to the board and its members) for some repairs / upgrades I am doing.
Since I am replacing the cam and lifters I figured I would put a new intake on as well. I am running a q-jet so I am looking at the Weiand street warrior dual plane or the similar in the edelbrock. curious if anyone has used one or the other.
this is for a 402 BB
thanks
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 03-26-2009, 04:54 PM   #2
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
Re: Weiand or Edelbrock intake for BB?
My 454 loves the Edelbrock Air Gap
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is online now   Reply With Quote
Old 03-26-2009, 05:42 PM   #3
BCOWANWHEELS
Intake needs to match the cam rpm range
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 03-26-2009, 08:52 PM   #4
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
I agree with BCOWANWHEELS - what cam are you running
FWIW the Edelbrock is made in the USA VS overseas for the Wieand
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 03-26-2009, 08:58 PM   #5
spinning wheels
spinning wheels's Avatar
thanks
How big and what duration is the new bump stick?
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 03-26-2009, 09:17 PM   #6
So.Cal.Super
It'll Buff Out!
Per Edelbrocks Recomendation
Part Number: EDL-2162
Cam Style: Hydraulic flat tappet
Basic Operating RPM Range: Idle-5,500
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 228
Duration at 050 inch Lift: 218 int./228 exh.
Advertised Intake Duration: 292
Advertised Exhaust Duration: 302
Advertised Duration: 292 int./302 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.500 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.500 in.
Valve Lift with Factory Rocker Arm Ratio: 0.500 int./0.500 exh. lift
Lobe Separation (degrees): 114
Intake Valve Lash: 0.000 in.
Exhaust Valve Lash: 0.000 in.
Computer-Controlled Compatible: No
Lifters Included: Yes
Lifter Style: Hydraulic flat tappet
This is still my daily driver so and I am not getting into head work etc.
So my choices for intakes 1 from there tech support and 1 from weiand.
Edelbrock
Part Number: EDL-2161
Engine Block Style: Stock/OEM standard deck
Carburetor Quantity: Single
Intake Style: Dual plane
Intake Finish: Natural
Intake Material: Aluminum
EGR: No
and
Weiand
Part Number: WND-8123
EGR: No
Thanks for the input!
Man Card Rules
Old 03-26-2009, 09:22 PM   #7
So.Cal.Super
It'll Buff Out!
Weiand is overseas? Its owned by Holley and I thought made in KY?
Man Card Rules
