U-bolts
Anyone know a good source for u-bolts? I'm in need longer ones. Got a decent price from ATS at 63.00 for front and rear, then they tried to put it on me with $40.00 s&h.
Re: U-bolts
local spring shop, where i got mine.
Re: U-bolts
Speedway Motors has them.
Too many dreams, too little money. |
Grandpa in the rustmobile...
Re: U-bolts
check hardware stores autopart stores etc etc im getttin some from custom automovite type store
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
#5 | |
Re: U-bolts
Spring shops on bigger cities will be able to make them right on the spot, usually with good hardened nuts and washers.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
![]() Join Date: Oct 2005
Re: U-bolts
They do have U bolts in their catalog that are 1/2" at a great price. I'm not sure, but it seems that application is for setups with leafs were you have 2 U-bolts on each side and trailing arm trucks only use one U-bolt on each side......so is the truck U-bolts a little bigger in diameter than 1/2"?
Anybody got a loose one the could measure?
72 Cheyenne SWB Fleet Nut & bolt frame off in progress...99.9999% - supercharged 383 - 4 wheel discs - relocated fuel tank - ![]() My Build Thread |
