Old 03-27-2009, 08:01 AM   #1
70STOVEBOLT
70STOVEBOLT's Avatar
McGaughy's brake kits
Anybody know if McGaughy's disc brake kit p/n 63157 for 60-72 trucks work with the stock drum-brake spindles? Found a kit on ebay for $269. The seller says they "should" work with stock spindles. Any info would be appreciated.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-27-2009, 10:20 AM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: McGaughy's brake kits
Anything I have read on the disc brakes has read that you have to have the 71-72 style spindles or aftermarket ones to work...the drum brake spindle won't work. But someone else that knows 100% can chime in...
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 03-27-2009, 01:58 PM   #3
neonlarry
neonlarry's Avatar
That kit is supposed to have come with spindles (I have that kit) it will not work with drum spindles.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 03-27-2009, 02:14 PM   #4
70STOVEBOLT
VA and neonlarry, thanks for the info.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 03-27-2009, 02:17 PM   #5
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
There's no mount for the calipers on the drum spindles.The spindles are about $49.00 or so IIRC.They do bolt up easily.If you swap spindles paint them before installing.They will rust if you don't.
Someone used to make(they may still) a kit with brackets that would bolt to the drum spindles and allow you to run disc brakes.I don't have the link anymore and can't remember who it was.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 03-27-2009, 02:26 PM   #6
70STOVEBOLT
I thought I saw some brackets on here a while back that would bolt on the drum spindles in the holes for the backing plates and the calipers would bolt to the brackets. Anyone know who makes 'em or sells 'em?
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
