Old 03-27-2009, 09:01 PM   #1
americanmusc1e
americanmusc1e's Avatar
700r4 shifts at 3000
Just got my truck back together and took it for a test drive. I got it to start going into fourth after a little monkeying and the part throttle shifts seem normal but at full throttle it shifts around 3000, isn't that a little low?
I figured it would shift around 4000, does anyone else have a 700r4 that shifts this low? Am I doing something wrong?
I set the TV cable according to the manual.
The trans is an '87 out of a camaro with a fresh rebuild, this was my first test drive.
thanks
-- Josh
Instagram: @americanmusc1e
OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread
FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread
1999 4wd OBS Tahoe - daily.
DM me if you can't see photos i posted
americanmusc1e is offline   Reply With Quote
Old 03-27-2009, 09:41 PM   #2
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Re: 700r4 shifts at 3000
Definately is too early to shift at wide open throttle. Check and make sure that tv cable is adjusted properly ie... tight enough.
--Josh
Old 03-27-2009, 10:11 PM   #3
70clone
70clone's Avatar
the only way to get it perfect is to get a tv corrector kit so that you have the right geometry sonnax makes a good one
70clone is offline   Reply With Quote
Old 03-28-2009, 05:12 AM   #4
67shortie
Green club
67shortie's Avatar
First thing I would do it floor the accelerator pedal and see if the TV cable is fully extended.
I mean, have someone floor it, with the engine off of course in your driveway, and tug on the TV cable and see if it still has travel.
If it does, you need to fix this by retracting the adjuster back in, floor the throttle again and let it adjust itself. You will know when you floor the pedal, the TV cable is fully extended and will not pull any more you are golden.
Hope that made sense, it's the middle of the night and I am tired. Dang work schedule.
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears
70 SS396 Chevelle 427/200-4R/3.73posi
61 Lincoln Continental, black on black
Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln
67shortie is offline   Reply With Quote
Old 03-28-2009, 03:35 PM   #5
americanmusc1e
I checked the TV cable this morning and it seems to be adjusted properly, the throttle had a little left in it when it was floored. I'm going to adjust it to get full rotation and try it again
I used a factory (GM) TV cable for a '85 chevy pickup
here are the brackets I used for my 4160
http://store.summitracing.com/partde...5&autoview=sku
-- Josh
Old 03-28-2009, 05:50 PM   #6
americanmusc1e
the throttle linkage now moves the throttle all the way. I took it out for testing and it shifts between 2900 and 3500 depending on the gear at WOT. The TV cable stays all the way in when I adjust it, Is my cable too long??
somebody help!!
-- Josh
Old 03-28-2009, 06:10 PM   #7
americanmusc1e
I double checked the TV cable, It is all the way out at WOT.
Despite having a shift kit the shifts are not firm, less firm than my old th350.
-- Josh
Old 03-29-2009, 04:35 AM   #8
38chevyhotrod
38chevyhotrod's Avatar
Is your wot really wide open?
Check if you can't also open your throttle on the throttle body?
Anybody can restore a classic, takes a man to cut one up.....
http://www.arnoldscustoms.com
38chevyhotrod is offline   Reply With Quote
Old 03-29-2009, 04:07 PM   #9
americanmusc1e
the throttle linkage is adjusted properly and the throttle opens all the way and the TV cable seems to be adjusted right
-- Josh
Old 03-29-2009, 08:02 PM   #10
sv10001975
sv10001975's Avatar
what gear ratio does your truck have and what ratio was in the vehicle that the trans came out of? if the vehicle it came out of was a 2.73 or 3.08 and you put in a vehicle with 3.73 or 4.10 then the shift point is about right. What you will have to do is get a govenor recalibration kit from summit/jegs and recalibrate the govenor. This is very simple and takes about 20 minutes to do.
sv10001975 is offline   Reply With Quote
Old 03-29-2009, 08:05 PM   #11
americanmusc1e
My truck has a 3.08 not sure about the camaro it came out of but my speedo is on (I checked it against my brothers truck) so I assume it was probably pretty close
-- Josh
Old 03-29-2009, 08:18 PM   #12
sv10001975
sv10001975's Avatar
you may want to pull the govenor out and check it to make sure it is operating properly. it is just a few weights and springs and doesn't take long to check. just sounds like a govenor issue to me.
Old 03-29-2009, 08:24 PM   #13
texanidiot25
Eat My Rust
texanidiot25's Avatar
rear gear ratio shouldn't have an effect on shift points..
I agree with checking the govener. But, if your saying it has soft shifts, I still feel the TV cable has something to do with it, it boosts pressure and firms up the shifts.
Auto Camaros had 3.23 gears if I recall right.
texanidiot25 is offline   Reply With Quote
Old 03-29-2009, 08:38 PM   #14
americanmusc1e
Its hard to tell how hard the shift is when it shifts at 3000 LOL, but it feels soft to me
-- Josh
Old 04-02-2009, 08:45 AM   #15
americanmusc1e
talked to my transmission guy yesterday and he said the TV cable was adjusted properly. guess I'll try to get a governor recalibration kit
-- Josh
