PIMPING RIDES
rear disc brakes
hey i need help with this bracket .i took the axles off and installed the brackets they fit but when you put the rotors on and the calipers the 2 bolt that hold the caliper to the bracket how can you get those bolts in there and the nuts .what keeps them attached to the bracket .i can slide the bolts in from the back but you can't put the nut on .help this is installing 95 impala ss brackets.
1964 CHEVY 1/2 C/10 FLEET ![]() 1981 CHEVY 1/2 C/10 FLEET ![]() 1995 DODGE 1500 V6 FLEET ![]() EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
![]() Join Date: Nov 2006
Re: rear disc brakes
I'm confused.
I thought you recieved brackets from captinfab? That's weav1's set up in the pic. It would help if you took a pic of your brackets, calipers, rotrs, ect and not use someone else's. I thought captinfab's used a weld nut anyways. http://67-72chevytrucks.com/vboard/s...d.php?t=334885 Irregardless, like Joe said, just ask him. Maybe they're not for impala calipers/rotors like the other guy's were? |
60-66 Nut
![]() ![]() Join Date: Mar 2007
The brackets that BIGPIMP got from me are the ones for the Impala SS rotors and calipers. The brackest I made have the spacers stich welded onto them. He has PM'd me and I replied, and am now waiting to hear back. At this point I'm not sure what the issue is, but we'll get it figured out. I told him to get a pic or two also.
#4 | |
PIMPING RIDES
i have a pic of what i'm talking about i have the bracket mounted then when it comes time to put the caliper braket on i can't get the bolts in there look at this pic and you will see
PIMPING RIDES
the rotors i have don't have as much space or opening .and they are brand new
#6 | |
60-66 Nut
I'll do some more checking and get back to you.
#7 | |
PIMPING RIDES
http://cgi.ebay.com/ebaymotors/ws/eB...3AIT&viewitem=
PIMPING RIDES
the space that i have put red in is what i'm talking about .i'm just wandering if they sent me the wrong rotor .but when i look at the pic in weav1 thread the space looks the same as my rotors .so i wonder how he got the bolts in there .the second pic is weav1 they look about like my rotors
PIMPING RIDES
i was thinking do they make a tap that would make threads in the metal .captainfab welded spacer on there and if i could just make threads in the spacer then my problem would be solved .then the bolts that he supplied would just screw into the spacer see below
Cantankerous Geezer
Going to a bigger bolt is not recommended since you would have to oversize the holes in the caliper bracket.
Is the problem interference with the rotor? Or access to the nut? If it's access, you can weld non-locking nuts to the plates. Remove the plates and bolt up the caliper bracket. Then tack weld the nuts to the plate. When you re-assemble use loc-tite. If it's clearance you would probably want to fill the bolt holes, drill and tap for the bolts provided. Assemble with loc-tite. Or install threaded inserts. This is why I recommend buying all of the parts from one source, but that's a whole nother issue.
Fred There is no such thing as too much cam...just not enough engine. ![]() |
60-66 Nut
The issue that BIGPIMP is having is an interference with the bolt head, (or the nut depending on which way it is used) and the inner lip of the rotor. I have explained the options to him via email and I'm waiting to hear how he would like to remedy this issue. Future brackets will have a threaded hole in the bracket to avoid further confusion.
Hey Y'all!!
I'm with Joe on this one. Looks like the bracket may be installed backwards. Captain?
Just hopin' I live long enough to finish something!!! |
#13 | |
PIMPING RIDES
why not make the whole in the caliper bracket bigger it goes from a 7/16 to a 1/2 inch which the bolts i have almost goes thru there now .will that little bit bake the caliper bracket weak .if you turn the bracket around so that the spacer is on the back side the rotor will rub .captain fab is right the spacer needs to be a nut from now on .i am going to try to use a die to make the spacer a nut .then i think it will work .i will post further progress tomorrow .see where the spacer is in the orignal post by weav1
1964 CHEVY 1/2 C/10 FLEET ![]() 1981 CHEVY 1/2 C/10 FLEET ![]() 1995 DODGE 1500 V6 FLEET ![]() EAST http://www.flickr.com/photos/bigasspimp/?saved=1 Last edited by BIGPIMP; 03-29-2009 at 12:19 AM. |
#14 | ||
60-66 Nut
This should prevent further issues
#15 |
Cantankerous Geezer
If that's the case I'm out of here. I will not help those who are deceitful in posting.
#16 | |
PIMPING RIDES
to be honest on this setup there doesn't need to be a spacer just thread the bracket .i think the space very with the rotors you get .here is some pics
1964 CHEVY 1/2 C/10 FLEET ![]() 1981 CHEVY 1/2 C/10 FLEET ![]() 1995 DODGE 1500 V6 FLEET ![]() EAST http://www.flickr.com/photos/bigasspimp/?saved=1 Last edited by BIGPIMP; 03-29-2009 at 06:39 PM. |
#17 | |
PIMPING RIDES
the end
