Old 03-28-2009, 09:38 AM   #1
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Electrical Problem
Tail lights and brake lights work fine with head lights off.
When I turn the headlights on.....the brake lights come on.
Cant see where I have any wires crossed.
Any body had this problem?
Joey~AP is offline   Reply With Quote
Old 03-28-2009, 01:06 PM   #2
19GMC63
19GMC63's Avatar
Re: Electrical Problem
so does everything work fine when you pull the switch out once for park lights?
did this issue just pop up? is this original wiring? do you have a trailer harness?
do you have good tail light housing grounds?
need more info.
19GMC63 is offline   Reply With Quote
Old 03-28-2009, 02:45 PM   #3
62 short step
62 short step's Avatar
Sounds like a ground is not hooked up in the back.
www.louisianaclassictruckclub.com
1965 c-10
86 chevy c/k 20
62 short step is offline   Reply With Quote
Old 03-28-2009, 04:21 PM   #4
Joey~AP
TexasBowhunter
Joey~AP's Avatar
I think you are both right. I think the ground is gone and I am back feeding.
Rippin it apart now.
I remember the light socket was a 2 wire and the PO had wrapped a wire around the metallic base for a ground. That may be the whole problem!
10gmc63...
66 truck
79 harness and fuse box hootus
no trailer harness
Old 03-29-2009, 09:25 PM   #5
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Fixed it!
Kinda......
The old lights had a 2 wire socket and a 3rd wire wrapped around the metallic base and covered in tape for a ground.
The 3rd wire wasnt a good enuff ground, so the tail lights were back feeding thru the brake lights.
I removed the bulbs from the bed tail lights and everthing started correctly.
I guess I need to find some late model 3 wire light sockets.
Old 03-30-2009, 12:08 AM   #6
protrash64
Resistance is Futile
protrash64's Avatar
I had tail issues for a long time. I finally pulled the housings apart completely including the pigtail that drops down inside the tailgate. I found the springs that compress when you install a bulb were getting hung up and not making contact with the bulb. I sanded the inside of the socket to clean them and I lubed up the contacts best I could. I re-did the mounting screws and clips also. It took all of the stuff being reworked and cleaned to get it working properly, and its confusing as hell when they are doing all that weird stuff.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
